Overheating | FerrariChat
Overheating
Discussion in '308/328' started by Sundmaker, Jul 20, 2011.
  1. Sundmaker
    Sundmaker Rookie
    May 26, 2009
    17
    New Orleans, LA
    Well...My 328 has been running a bit warm lately. So, at run temp, I got out....the fans are not turning. Checked the fan fuses...neither is blown. Replaced the relays....no improvement. So, I unpluged the wires at the bottom of the radiator and I jumped them together. BOOM Both fans cranked. I guess the sensor at the radiator is bad. All Agree? Anyone know who has the part?
    Thanks,
    Trey
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Check the parts xref post you might find it there. I have seen posts on Fchat. Good luck. You can, I think take it to NAPA and they can match it up. You need to find the temp that closes the switch and find one close.
  3. vp277
    vp277 Karting
    Mar 1, 2010
    101
    LI, NY
    RADIATOR COOLING FAN SWITCH 2 POLE
    VW PN# 82395948182 180F
    VW PN# 82395948172 160F
  4. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    I had the exact same problem, and it turned out that my sensor was fine.
    It's also possible that you have air building up at the thermostat housing, which will prevent the T-stat from opening up fully...and results in the coolant at the radiator never getting hot enough to trigger the sensors. (Ask me how I know!)
    So take a moment to bleed both the t-stat housing (be careful if you don't have Verrell's easy-bleed screw), as well as the knurled knob on the top right of the radiator (which is an easy-bleeder from the factory.)
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    You could also pull the switch from the bottom of the radiator and put it in a pan of water with a thrometer and a DVM and see when/if it closes. But the switch is only $15. For that much trouble I probably would put a new one in no matter how it tested.
    Perhaps this is an excellent excuse to buy one of those non contact IR thermometers and see what the radiator temp is.
  6. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    That VW switch might not be the same, and over heating could potentially ruin your engine! Why use non-original parts when you can spend $900.00 for the original part in a super nice yellow box with a horsey on it and have peace of mind? Isn't your ferrari worth it??
    No. It's the same darn part and you're an idiot if you let ferrari rape you on a part that ferrari sourced from a non-ferrari parts bin in the first place...
    Of course, if you enjoy throwing your money away foolishly then by all means walk into any ferrari dealership and get a free latte with your raping....
  7. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    #7 Iain, Jul 22, 2011
    If its been getting warm in traffic then OK, it might just be the fan switch. If its staying too warm on the open road then you need to look elsewhere because the fans (or lack of) won't cause that.
    In that case, bleed the system at the thermostat & the radiator & then check the coolant level. If its low then that would cause overheating & the most likely cause would be a bad expansion tank cap. But also pressure test the system to look for leaks elsewhere.
    If you don't have any coolant loss & its still getting too warm then check the waterpump belt's not slipping, change the thermostat & after that you'd be looking at the radiator being blocked.
  8. wernerg
    wernerg Karting
    Jun 29, 2006
    50
    Danville CA
    Werner Goertz
    Iain, what is your definition of "getting warm in traffic"? I take it you're referring to the coolant temp, not the oil temp?
    My 328 never goes beyond the midway point on the coolant, but I am paranoid, I guess. So that's why I am interested in other drivers' observations on what's "normal"
    Thanks!
  9. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    The thermostat is designed to open at a specific temp (usually 185-195) which means that your car should run on the open road around 195. If you get stuck in traffic and the temp starts to rise, the temp switch should kick the fans on. (Also above 195).
  10. PT 328
    PT 328 F1 Rookie
    4,007
    Your fine. Mine will creep a tad over mid-line in traffic then the fans kick on and bring it back down. I had an issue with the gauge reading high. I fixed that by cleaning the connections on the back of the gauge.
  11. wernerg
    wernerg Karting
    Jun 29, 2006
    50
    Danville CA
    Werner Goertz
    I know, I know - I am just paranoid ;-)
    My fans run pretty strong, and as soon as I reach the mid-point, they kick in, especially in slow traffic, or standing at a stop light, and bring the coolant temp back down again.
  12. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    #12 Iain, Jul 23, 2011
    Definition of "getting warm" is going above 195 whether the fans kick in or not (and they should at that level).
    Mine runs at the second mark on the gauge unless sitting stationary when it will go to the middle (i.e. 195) & then the fans kick in, bring it back down to the second mark & then cut off - and repeat ad infinitum whatever the weather.
    The Thermostat does not run the car at 190/195 - its more like 175 during normal operation.
  13. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,875
    Mike 996
    Yep - sounds like perfectly normal 328 operation.
  14. chriskopin
    chriskopin Rookie
    Sep 27, 2010
    8
    Branchburg, NJ
    Chris Kopin
    Do the fans have more than one speed. My gauge goes to the 3/4 mark sitting in traffic, the fans come on but don't seem to make a significant difference in the temp.
  15. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    AFAIK the fans will be on or off.
    What temperature is that on the gauge?
    Cooling on 308s can be a bit marginal - might be you need to investigate this further.
  16. chriskopin
    chriskopin Rookie
    Sep 27, 2010
    8
    Branchburg, NJ
    Chris Kopin
    My gauge is in in Celsius. On a highway is reads about 90c, once traffic starts it goes to 110c, the gauge tops out at 120c. Of course the outside temperature this weekend in NJ is over 100 degrees...not helping matters.
  17. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    #17 Iain, Jul 24, 2011
    I'd be getting an infra red thermometer onto that to see if what the gauge is telling you is accurate. If it is (IMO) its running too warm.
    Do the fans cut in or not?
    ETA - noted that you said above that they do. If so then what temperature (on the gauge) are they coming in at? They should bring the temperature down, not just stop it rising, so if they are not doing that then it suggests your radiator is a bit marginal.
