Oxygen sensor | FerrariChat
Oxygen sensor
Discussion in '360/430' started by whatheheck, Sep 29, 2014.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  2. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    #2 ar4me, Sep 29, 2014
  3. slracing
    slracing Formula Junior
    Jan 13, 2011
    438
    Europe
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Excellent! Thank you!
    Dan
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    None, no issue at all. Engine runs perfect.
    I am now thinking its possible the codes are being thrown because I have Tubi exhaust. Perhaps I should start another thread and ask the Tubi owners if they get CEL oxygen sensor codes too post Tubi exhaust installation.
    Dan
  6. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
    Can you burn a piston by ignoring these codes?
  7. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Cat-back exhaust should not give you CEL codes. Though, the Tubi exhaust probably eliminated the exhaust valves (should be #37 in above diagram), and you need to plug the vacuum hoses previously connected to the stock exhaust valves. I would check that.
    If headers (with pre-cats) or main cats were changed/removed then all bets are off, but you seem to have stock headers and cats, so that shouldn't be your issue.
  8. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for the info.
    It appears Tubi is not the culprit for the CEL.
    I will check to make sure the vacuum hoses are capped and start checking the oxygen sensors.
    Thanks again.
    Dan
