P 4/5-Enzo Rear Shocks | FerrariChat
Discussion in 'Technical Q&A' started by Napolis, Jun 16, 2015.
  1. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    After about 12K miles all bushings/uniballs have a LOT of wear. This wear transmits noise into cockpit and is way too much for this mileage IMO. We checked around and other Enzo's seem to have this issue as well. We're going to redesign all of this to make it much more robust.
    Any of you have these issues?
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    That's pretty average quality by the sounds of it mate.
    I have no doubt you and your guys will come up with an excellent solution.
    Please post pics along the way.
  3. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #3 Napolis, Jun 16, 2015
    Same issues in front. We'll replace all with much more robust components.
  4. dwhite
    dwhite F1 Rookie
    They probably figured no one would put on that kind of mileage ;-). Atleast not within 25 years.
  5. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    True.
    We thought these noises were body creaks but CF really amplifies noise so if you hear something in your CF car do have it checked.
  6. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    That's pretty common in lesser cars where owners have installed aftermarket suspension upgrades with spherical bearings replacing OEM rubber bushings.
    Coilover shock top mounts and sway bar end links are the usual culprits - they ALL develop rattles and clunks. I had a set of Ohlins with spherical bearings in the top mounts - great quality, it took 6 years for them to start getting noisy, but I'm told it is inevitable at some point.
    It sounds like the Enzo chassis used similar bearings for greater precision and less flex/slop in the suspension; with the tradeoff that they need to be "serviced" (replaced) at shorter intervals.
  7. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Same issue with the AMG mods on Mercedes suspensions. Most time they get replaced by a stock rubber bushed unit, LOL
  8. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    Hi Jim,
    here we chatted about that topic a bit about 2 Years ago. Last entry that side!
    http://www.ferrarichat.com/forum/288gto-f40-f50-enzo-laferrari/402508-driving-ferrari-supercars-street-6.html
    We now have about 24.000 kms or about 15.000 mls on our Enzo. I searched for it so often, but just can´t lokate it. Sometimes i feel something at the rear shokabsorbers, but nothing i can replicate. So far, its just the noise and everything feels solid. No movement in the bushings at the TÜV testing station so far, but need to go there anyway to get it new.
    Seems, it was not the best choice from Maranello to use the same bushings as in the F50 on most of the suspension... The we have ZERO problems after lot of track time.
    Please pm me with Your solution or share it here!
    Give my best to Paolo and Sal (remember him on our California ;) ) Was a nice lunch with you guys in Turin!
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    We think it's in the lower vertical push rod ends. We're looking into more robust ones. Put a lever on the wheel center bolt with the car jacked up. That's how we found the play.
  10. Rifledriver
    37,121
    I am not sure a zero compliance, low rotational friction joint with long lasting road car service qualities exists, at least not better by a large margin. I think the performance/wear ratio is, for now anyway, a trade that those manufacturers have decided is OK.
    A long, long time ago a man said "Speed costs money. How fast you want to go?".
    I don't think that's changed.
  11. jochem00
    jochem00 Formula Junior
    Jun 19, 2014
    344
    Netherlands
    Can't complain after 20 years.
    it is the age of the rubbers wearing them out. so if you replace with OEM, you will be fine for the next 20!
  12. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Road cars need rubber bushes ... that will solve it and enable 100,000 miles before next replacement :)
    You can get spherical bearing boots though, but IMO you either do expensive 12k rebuilds or replace with rubber.
    Pete
  13. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    #13 bcwawright, Jun 17, 2015
    Lots of new technology out there since my days of racing in the 60's,70's, and 80's.
    Some of the new aerospace plating/coating technology along with adequate shielding/protection can get those heim joints and monoballs to last a little longer.
    The pictured pillow balls with seals and a special coating.
    Boot cover for rod end/heim joints..
  14. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,965
    The Cold North
    Tom
    I agree. Lambo got rid of the heim joint suspension set up with the diablo. I don't think I have ever seen a countach rear suspension not needing some sort of attention. And the parts are damn expensive. Definatly not designed for the long term. Works very well when new however. Practical? Nope..
  15. ferrariidiot
    ferrariidiot Rookie
    Dec 13, 2005
    4
    Had an enzo once that was emulating noises in the chassis giving the impression of the control arms slamming the tub when hitting the slightest bump. After a substantial amount of time looking in the wrong direction it turned out to be the brake pads rattling around in the caliper. We fabricated new spring clips to retain the pads and all was well from that point on. Ferrari later issued an updated clip for this same issue.
  16. mechaniker
    May 30, 2004
    608
    Germany
    Jim,
    any updates?
