P 4/5 Won't recognise keys?? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Napolis, Oct 24, 2008.
  1. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    No help from the P4/5 owners site? ;)
  2. DGS
    DGS Seven Time F1 World Champ
    72,965
    MidTN
    DGS
    So hook the ECU uplink connection to your internet feed and let the factory VPN in and reprogram. ;)
    (When a computer costs that much, doesn't it come with an "integrated lights-out" connection? :p)
  3. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The odd thing is that the battery was always fully charged and after the clutch was replaced the car was started without issue many times. It was driven almost 200 miles. Strangely when shut off in my driveway it wouldn't start 5 minutes later and shows keys locked out.
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Gee.....I remember back-in-the-day ( not too too long ago ) you had to put the key in a slot just near the door handle and turn it to actually "lock" the door.
    ...the alarm system was the bouncer at the club or restaurant you were attending saying....move along folks...move along.
    ...ah, the good ol days :D
    Shamile
    Freeze...Miami Vice !
  5. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,739
    NYC
    Buzz
    Somewhere up there, Enzo is laughing his a** off. Computers? Fobs? The clutch affecting the lock? Yow!
  6. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    You may have used up the battery, Jim. Running, it was OK, early it had enough voltage to start and run, but charge failed. Could be bad alternator or ground too. Try code, but check battery/ground first. If battery shut down BTW, the ECU has to relearn some parameters, so a 10-15 min. drive best, and use it like you normally would.
    L
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    #32 Meister, Oct 25, 2008
    On some level, the internet is cool in the fact that paupers like us can talk to a king...
  8. B R
    B R F1 Rookie
    Aug 31, 2005
    2,824
    Los Angeles, CA
    B R
    Always start with the most simple things. Today's cars are so electronic dependent, that problem batts can cause all sorts of whacky behavior. Good luck, I'm sure you will get it back up & running fine soon.
  9. DMC308
    DMC308 F1 Rookie
    Aug 19, 2006
    2,574
    Seattle/Noosa
    D
    #34 DMC308, Oct 26, 2008
    Better sell it. :(
    Bad starter or bad starter connection maybe?
    Any current?
  10. Etcetera
    Etcetera Two Time F1 World Champ
    24,274
    C6H14O5
    Yep, and I'm sure that you'll find Stackhouse to be down to Earth and pleasant at all times.
  11. js430
    js430 Formula Junior
    Mar 9, 2005
    373
    Seattle
    Jerry Kahane
    #36 js430, Oct 26, 2008
    OK, I think I know the answer to this.
    If the battery is indeed ok, something is causing interference. The fix is to move the car to a different location, and simply press your key. So, you need to flat-bed your car a mile or more in several directions away from your house and see if the keys work before you resort to deeper surgery/fancy procedures.
    You could also try it in your garage with the doors closed, as the doors plus the lift tracks plus the house wiring and plumbing (if it's metal) might act as a bit of a Faraday cage and block out the interference. Obviously, don't leave the car running without opening the garage doors.
    Did any fancy telecommunications or AV gear or some other electronic doodad get installed recently at your place, or your neighbors'?
    Let me know if I am right. Good luck.
  12. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    It's it's way of revolting against today's economic circumstances..........
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Lee the battery is fully charged. It's the ecu.
  14. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    It's worked in that enviroment for years.
  15. DGS
    72,965
    MidTN
    DGS
    #40 DGS, Oct 26, 2008
    That's a long shot, but it might be a possibility. I had tons of (intermittent) problems with my garage door remote when I lived near the DEC chip plant (until Intel took it over).
    But I wouldn't expect a lot of electronic chip factories in a neighborhood where you'd park a P4/P5. ;)
    But it might be something new in the environment. Did your 'hood just get FiOS?
    On the other hand, the interference might be local -- from another key on the same keyring. Have you tried using the key by itself off the keyring, with the cell phone and any smart cards kept far away?
  16. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Jim, I read Greek. Send it to me.
    We'll get to the bottom of this.
  17. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    One thing you can do yourself that could be the problem is to check all of the grounds. Sometimes a ground connection isn't good and while the battery is fully charged, the ground to the ECU has high resistance, and you can get a low voltage across the ECU...
    It is worth a try to trouble shoot that and make sure it isn't a grounding issue.
  18. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Chris,
    Very, very funny. But I believe that Jim is referring to a "different dialect" of Greek that cannot be interpreted by mere mortals.
    David
  19. js430
    Mar 9, 2005
    373
    Seattle
    Jerry Kahane
    Yes, but something could have changed...neighbor installed something, new cell phone tower/repeater, even in your own house, new electronics, etc.
    This is a known issue near a certain lighthouse in France. Exotic owners pull up to take pics, then can't get their cars restarted. Local tow truck operator takes their car a mile away, and all is well again.
  20. fatbillybob
    Aug 10, 2002
    29,253
    socal
    There seems to be all kinds of universal problems with the factory integrated alarms. There are a million Fchat alarm threads. I started this one:
    http://ferrarichat.com/forum/showthread.php?p=138143764#post138143764
    I think we need to solve this problem once and for all for all post 1995 Ferrari owners. With so many people involved even if someone needed to be hired to figure it out many would contribute to the cause. I bet there is someone here on fchat who has the know how to do it.
  21. kens
    kens Formula 3
    1,351
    I had a very similar problem. In my case, the ECU would not power up. I had a power junction that was not tightened after servicing, after a few hundred miles it loosened to the point that I got a no start condition. The key code light failed to go out, indicating recognition. The key code failed to recognize the keys because the ECU was not powering up at all.
    So, if any power junctions were touched during the clutch replacement, review for tightness.
    Ken
  22. Buck_nekid
    Buck_nekid Rookie
    Nov 5, 2005
    24
    West Virginia
    Jack
    I'm going to reply here at the risk of looking real stupid. I know why some cars with transponder based keys 'lock up' and drop the programed keys. I know this happens to Ford, Chrysler and Honda. The car can't "see" more than one key at a time. I had a tech admit it to me, but the dealership wouldn't acknowledge it. Someone has two programmed keys on the same key ring, and if the moon is right and the stars align the car will "see" both keys and they are stranded. I don't even know if Ferrari uses a transponder system in their vehicles but I would imagine so.
  23. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Hi
    Thanks but not the case here.
  24. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Will check everything and report but as I'll be away won't happen until 11/12.
  25. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Yeah, it's called Italian................................
