P 4/5 Won't recognise keys?? | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by Napolis, Oct 24, 2008.
  1. DGS
    DGS Seven Time F1 World Champ
    72,960
    MidTN
    DGS
    In Greek, or in Geek? ;)
  2. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    Oh, man, I was hoping that this wouldn't come up. Honest, I really didn't drive it all that much. Okay, so I pushed it a little bit, but BFD. I figured that since you was out of town that you or Sal wouldn't notice. Aw crap, I guess I left the wrong key. Listen, I'm sorry. And, uh, about those dents on the inside of the roof? You need to talk to Count Whathisname about that. It wasn't me man. Seriously, I wouldn't have done that to your car. I tried to tell the Count about the NoTell Motel, but he wouldn't listen.
    Dale
  3. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    Why would THAT car need more than a simple lock and cylinder key starting system? It seems that there's an added level of Italian complication that gives trouble when it really isn't needed at all. Just my 2c.
  4. tazandjan
    39,312
    Bruce- Welcome to the world of "Why did they do it that way?" or "Why do the oxygen/lambda sensors/ECUs fail on a really expensive F car when they give no trouble on a (you pick) Chevrolet, Mercedes, Porsche or rice-burner?" You have to put up with the weirdness to play with the prettiest dynamic toys in the world. But at least they are expensive to fix.
    Taz
    Terry Phillips
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    So far the moral of this thread is to buy/invest in a car w/mech fuel pump, carbs, battery, key and 4 tires.....
    KISS.
    Thechnology is "KILLER" until the power goes out.
  6. fatbillybob
    Aug 10, 2002
    29,252
    socal
    post 1995 all ferraris have integrated alarm ecus that talk to the motronic ecus. They are inseparable once the talk once together. I wnat to know what happens if you remove the alarm ecu and then swap motronic ecus and then try and start the car. Could you then have an alarm free late model ferrari????
  7. MordaloMVD
    MordaloMVD F1 Rookie
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    Totally agree here. Jeezz. How's the back Jim?
  8. Diablo
    Diablo Formula Junior
    FYI:
    All Enzo keys do not have a battery in the key.It does not have any buttons either. It has an immobilizer chip in the key which will have to match the module in the car.
    Jim will need the electronic code and both keys with and SD2 to reprogram them.Good luck.
    For some reason it lost it's receiver code at the ECU.
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Yes that's what we think as well.
  10. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    Thats right, do need the sd2 for that one, doesn`t have the remote buttons,
    suppose it has to go to the dealer at this point.
  11. dretceterini
    dretceterini F1 Veteran
    Apr 28, 2004
    7,289
    Etceterini Land
    Dr.Stuart Schaller
    Is it possible Pininfarina might have the information needed? After all, they must have taken the system apart when the car was bodied there...
  12. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Change that to 1999 and on 360's and then your statement is correct, not on the 355's. The 360 alarm ECU burns the code into one Motronic ECU. The ECU's can be swapped and then the code is burned into both and only will work when mated with that alarm ECU.
    The 5.2 alarm systems can be bypassed (Dont ask) but it is no easy task.
  13. DGS
    72,960
    MidTN
    DGS
    #63 DGS, Oct 27, 2008
    Hmm. Ignition: toggle switch. Starter: push button.
    After all, it's not like someone could pawn it off among all the other P4/5s on the market. :D
    And how often do you park it at Walmart, anyway? ;)
  14. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    So, did the pig start? Just because the battery is charged doesn't mean the ECU gets any/enough juice. Palin wears glasses, but the eyes are empty :)
  15. Etcetera
    Etcetera Two Time F1 World Champ
    24,272
    C6H14O5
    Maybe the pig would start if he put lipstick on it.
  16. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Palin hasn't quit yet.
    Art
  17. tfazio
    tfazio Formula 3
    1,983
    Michigan
    Napolis,
    Is there an update on this? I know you said you wouldn't be able to get to it until the 11/12. However, I see that you are around since you picked up your 8C yesterday.
  18. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Nope. Sal (my mechanic) is still in Europe.
  19. tazandjan
    39,312
    Jim- Please tell us about the Alfa.
    Taz
    Terry Phillips
  20. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Battery seems to have voltage regularity issues. (Not charging issues)
    The two ECU's don't communicate unless voltage is perfect. They shut down to prevent damage to ECU's.
    Should be under control with new battery.
    Alt. is fine. All Grounds are fine.
    Programing is fine.
  21. Sfumato
    Nov 1, 2003
    10,194
    Angus Podgorney
    That little ECU slave setup is VERY picky. Ask me how I know ;)
  22. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #72 Napolis, Nov 12, 2008
    The problem seems to be when you remove the battery from the system. It can trigger faults that don't show up immediately which is what happened here.
    Computers are a PITA.
    Once again thanks to WWOC for helping Sal out.
  23. Sfumato
    Nov 1, 2003
    10,194
    Angus Podgorney
    Microvoltage changes can cause fault codes, some systems are less tolerant than others. Usually fault codes never make it beyond storage rather than idiot/CEL's. SD3 picks them up.
    I've got a great story for Sal about getting my SA running as 2 sixes, as the DME's wouldn't link as master/slave. FNA said it couldn't happen. I asked where I could EM the video. They flew someone out, told dealer they were idiots first. Then FNA couldn't fix it. Pretty damn funny.
    Us'n po' white trash doan get no count from them Joisey folk.
    At least it is easier to fix than hot soak problems.
  24. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    More fun to fix those when you are running six Webers...
  25. Sfumato
    Nov 1, 2003
    10,194
    Angus Podgorney
    True Dat. Even 3 and that crappy yellow line.
