P/S Line-Engine out | FerrariChat
P/S Line-Engine out
Discussion in '348/355' started by fcmotorsports, May 15, 2008.
  1. fcmotorsports
    fcmotorsports Karting
    Feb 4, 2008
    103
    Garage
    michael
    Well I've used every foul word in 6 different languages and still can't get the power steering hydraulic hose broke loose to drop the engine.
    Any suggestions short of learning more curse words..lol
  2. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    hi Michael
    ah yes, you must be working on an F355....and referring to the 22mm PS line (to the right of the rubber line)
    unfortunately.... they are all a Mu%#^$ther F%$^%ker to get off.....so you're not alone
    some ideas
    - try vise gripping the 17mm end that disappears into the firewall.....if you're able to secure it with a 17mm open end flare nut wrench than that's good
    - put a 22 open end .....cut off possibly....so you can get a pipe on the end of it (12"-18")....and try that
    make sure you got ahold of the 17mm end.....you don't want to twist that
    i've seen this done......that's how i know it's a beeotch
    worst case........how about disconnecting the line at the pump.......(goes under the heat exchanger on its way to the pump) and then pulling the engine out.....then you can better deal with the stuck line at the firewall......i know i know......that's alot of work......but it might be your last resort
    just ideas
  3. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Excellent, glad I wasn't the only one! That PS line was the worst part of getting the engine out. I never could loosen it at the firewall, didn't want to round it off too bad. I was about to cut it in half...until I saw that a new one was like $400. So resorted to plan B, disconnected at the pump. This was a serious pain too because as posted above I had to snake it through that center section and it isn't all that flexible.
    Good luck!
  4. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    If you have 22 nut that is difficult (speaking kindly) , there are many o2 sensor wrenches, sockets, crowsfoot etc that might be useful. They are also cheap enough that you can buy several.
    Jay
    and if you use vice grips, nobody will know for at least 3 years.
  5. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    If I remember now the prob was the 17, I couldn't get the flare wrench on it.
    And in 3 (well, 5) years I'd know that vice grips were used when I take it out again!
  6. fatbillybob
    Aug 10, 2002
    29,178
    socal
    it can take heat
  7. fcmotorsports
    Feb 4, 2008
    103
    Garage
    michael
    That is funny.....came home last night and was thinking about doing the same thing... cutting that sucker, but YIKES!!!!!!!!!!!!...that hose is EXPENSIVE...lol
  8. fcmotorsports
    Feb 4, 2008
    103
    Garage
    michael
    I was thinking about doing that, but way tooooo much fuel vapor and fuel in that area...plus I don't have a small enough torch to get in there, it's really tight.
  9. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    #9 jm3, May 16, 2008
  10. windsock
    windsock Formula 3
    1,160
    Those of us who do these frequntly have bent a custom wrench to get the angle correct on the 17mm fitting then it actually comes undone rather easily.
  11. fcmotorsports
    Feb 4, 2008
    103
    Garage
    michael
  12. fcmotorsports
    Feb 4, 2008
    103
    Garage
    michael
    I'm using a GearWrench flex-head 17mm flarenut wrench on the fixed line.........regular 22mm open end wrench on the hose side. I'm going to try a 22mm flarenut crowfoot and a pullbar on the hose side as my next step.
    Undone rather easily???????? I may need to go on steriods.....lol
