P0455 code help? | FerrariChat
P0455 code help?
Discussion in '360/430' started by rdaino, Feb 16, 2008.
  1. rdaino
    rdaino Rookie
    Jan 11, 2006
    22
    i was hoping someone might have a more detailed answer to the above code i get on my 2003 360. i know it is a evaporative emission comtrol system leak! as in what part is malfunctioning? it does not effect the car one bit and i drive it normally but the CEL will come on. so any help on what needs to be replaced the next time i have it in would be helpful. so until then i just drive it!
    thx
    rob
  2. AWJ
    AWJ Rookie
    Sep 5, 2005
    12
    Huntington Beach
    Aron J
    P0455 is a gross evaporative leak. If your fuel cap is not crossthreaded and the seal is still intact underneath the fuel cap then the only way to check it is with an evaporative emissions leak detection machine, or "smoke" machine. If you are smelling fuel I recommend a tow to a shop . The most common defect in that system is the roll over valves and seals that are located on top of the fuel tanks. If you own a Spider the capote assembly will have to be removed. Leaking fuel in a mid-engined car = disaster!
  3. tstafford
    tstafford Formula Junior
    Mar 4, 2006
    754
    Nashville
    Tim
