Anyone ever get this code? I was on some back country roads driving my ‘06 430 like it’s supposed to be and clicking thru the gears up and down... she pops into Neutral on its own. I upshift and it goes to 6th. Runs fine for a bit but I get the CEL. 40 min later, ripping gears again and same thing, pops into N. It’s drives fine. Clutch is fine (60% left) and no other issues are apparent. Any idea what this code would relay to? Things I should check? Thanks all!
Google it. When the code P0780 is set in the Powertrain Computer, it means that the Powertrain Computer or PCM is seeing a greater or smaller than specified RPM difference between the rotational speed of the Input Shaft and the Transmission Output Shaft as the transmission shifts gears.
I did indeed do that. And called dealer as well. They suggested the shift potentiometer is starting to fail. Apparently common issue on these cars. I will report back when I get it figured out. No issues running on the highway or normal driving. Thanks for your comment. Much appreciated.
Never came back and no issues. Might have been a fluke? Not sure tho but I’ve put on 500 more miles and it’s been good. Sorry I’m no help here. But if it comes back. I’ll holler.
