P1 codes for 97 550 | FerrariChat
P1 codes for 97 550
Discussion in 'Technical Q&A' started by modena001, Jul 11, 2004.
  1. modena001
    modena001 Rookie
    Mar 21, 2004
    32
    Seattle
    I picked up a OBD II reader and got the following P1 codes for my 550. Anybody know what they are?
    P1128
    P1446
    P1445
    P1124
    P1541
    I would really appreciate any help.
    Thanks!!
  2. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    curious. no OBD II codes of any sort listed in the Workshop Manual.
    i guess there's some other documentation that must come with their official OBD II reader.
    keep us all posted. g/l.
    doody.
  3. modena001
    modena001 Rookie
    Mar 21, 2004
    32
    Seattle
    Doody, there are generic codes that come with the OBD. It does not contain manufacturer specific codes for Ferrari. I am hopeful that someone will have them on the board. If I get the codes I will make sure and post them for everyone.
    Have a great weekend
    Brad
  4. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    according to this site http://www.flatratetech.com/pub34.htm , the 1 in the second digit means those are likely Ferrari-specific codes. P0XXX codes would be generic SAE OBD II codes, but P1XXX means they're OEM defined. i found this http://autoclinic.net/php_test/dtc_search.php OBD II code decoder, but it won't respond to X1XXX codes.
    fyi - i don't know jackola about OBD II codes. i'm just curious if not helpful :)
    doody.
  5. modena001
    modena001 Rookie
    Mar 21, 2004
    32
    Seattle
    I spent hours looking for the codes this morning no luck. I will calling Ferrari of Seattle tomorrow to see if they might part with the codes. I will keep you posted.
    Brad
  6. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Hope this helps..........
    P1124 Long Term Fuel Trim Additive Air System Too Lean (Max)
    1.Check fuel pressure
    2.Check HC CO emission with no lambda
    interogator
    3.Check injector and wiring
    4.Check ignition coil and wiring
    5.Check exhaust system leakage
    P1445 Catalyst Temperature (Vescovini) Range / Performance (Min/Max/Plaus)
    1.Check the wiring
    2.Check Vescovini ECU functionality
    3.Check thermocouple functionality
    P1446 Catalyst Protection Active Active (Max)
    1.Check wiring to injectors
    2.Check wiring to ignition coils
    3.Check all injector functionality
    4.Check engine emission base CO HC
    5.Check fuel tank level
    6.Check Vesovini ECU
    7.Check thermocouple
    P1541 Fuel Pump Relay Circuit Open (Signal)
    1.Check the wiring
    2.Check the functionality in diagnosis mode
    Sorry can't find code 1128
  7. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    eleven twenty eight...time for a cuppa tea!
  8. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Good idea, I'm off for a coffee
  9. modena001
    modena001 Rookie
    Mar 21, 2004
    32
    Seattle
    Thanks!!! Huge help. I'm not much of a mechanic but at least I can now go for another drive and see what errors happen again and then start to trouble shoot the stuff I understand and the rest I can have a real mechanic look at. Have a great day.
    Regards,
    Brad
  10. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    malcolm - from what document does that data come? i'd like to get myself a copy.
    thanks,
    doody
