Hello there, Anyone can help me with this code? i found online that this is: P1528 - Camshaft Control Outlet, Circuit sig I can see that there are 4 sensors on 4 cams on the rear side of the engine.. Which one should i check? before i take it to dealer
Maybe... I actually got that code on the OBD reader and was showing idle control.. When I searched online it showed me cam control error and I looked at the engine bay if there is anything I could do, seen 4 sensors on top of valve cover, 2 each side. And their plugs are hidden.
i would check for any burn wire on the harness to the camshaft sensors toward the firewall , the harness are very close to the hot header,
http://www.ferrarichat.com/forum/360-430-sponsored-yellow-compass-group/534454-leaky-valve-cover-since-ya-there.html
