P1531 code | FerrariChat
P1531 code
Discussion in '360/430' started by ForTax, Sep 28, 2016.
  1. ForTax
    ForTax Karting
    Nov 9, 2015
    131
    Queensland Australia
    Roger Garcia
    I have been chasing a problem with my 360 Ferrari manual for a while now.. I finally got a code of p1531 and found that the cam variator solinoide was way out of spec it was at 47ohms so I replaced the solenoid.. After I replaced it the car seam to run fine for a day and now I have the same problem, sluggish to rev and on blipping the throttle the cam timing is being retarded... Anyone have any ideas? Could there be a problem with the variator itself ? The car has 47000miles on it... How can you tell if the variator is bad? The car idles perfect and drives fine just sluggish when trying to blip the throttle...
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I was hoping we had a success on this_- assuming the solenoid admits oil to the variator, this alters the relationship of the cam to crankshaft. I would think the oil pressure operates in 1 direction only to move the cam shaft in the opposite direction to its running direction. When the oil pressure is released the pull on the cam belts would push the oil out of the variator and the cam would go back to its original position. It might have intermediate positions, but I think not as it would need some form of feedback to work.
    You might think about taking the plugs out and marking the exposed part of the cam shafts ( assuming it is possible) with a drop of paint and a reference mark on the engine. Turn the engine using the crank bolt and see if the 2 reference marks move the same when you move the crank in both directions. ie compare 1 bank to the other.
    Either the Variator is seized or it is worn internally so that the oil being admitted to it , is just passing the vanes and not adjusting the cam timing.
    If the movement of the 2 cams as seen by the paint marks is not the same then you know it is a variator problem.
    I have a drawing for you but cannot work out how to send it yet.
  3. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    What are the engine parameters? Put your SD2 in "Connect to PC" mode and select parameters. Look at cam timing and then compare that reading to the other bank. When you replaced the solenoid, do you reset the learned values with the SD diagnostic menu command?
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Do you know if the cam has just 2 positions ?
  5. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    Did you measure the resistance value of the new solenoid? You might want to do that before doing anything else, just to make sure that it's not 47 ohms again. If it is, something else is causing the solenoid to burn up.
  6. AD170
    AD170 Karting
    Jul 18, 2014
    79
    The variable timing system is not very exotic...Kia/Hyundai had the same system and it only moves the exhaust side 20 degrees. The ECM takes inputs from various sensors and them moves the solenoid by Pulse Width grounding in the ECM to move the shuttle valve in the solenoid. The shuttle valve then ports oil into the variator (other manufacturers call it a phaser) to either advance or retard the cam in relation to the cam sprocket. There is a three wire sensor that reports back to the ECM how much the variator moved. If the response was not what the command was, a DTC code is stored. First I would confirm you are getting source voltage to the solenoid (circuit loaded) and the ground wire to the ECM is good. Then I would confirm the three wire cam signal has good power and ground. Then I would compare the two signal wire voltages as you go from idle to snap throttle. They should track together. This is what the SD2/3
    is reading, its just converted data by the ECM. I would suspect your variator is bad since you replaced the solenoid. It can only be the solenoid, variator, wiring or ECM. Just a caution, sometimes a bad solenoid will take out an ECM.
  7. scuderia09
    scuderia09 Formula 3
    1,045
    #7 scuderia09, Sep 29, 2016
    Check the Harness wire down along the Valve cover wires or connector could be melted there close to the headers and alot of heat, check for any plastic melted
