P2407 Evaporative Emission System Code | FerrariChat
Discussion in '360/430' started by LeoExotic, Aug 15, 2019.
  1. LeoExotic
    LeoExotic Karting
    Nov 29, 2003
    163
    Manalapan, NJ
    Leonardo
    Anyone know what this code could be besides the gas cap>? "P2407 Evaporative Emission System Leak Detection Pump Sense Circuit Intermittent/Erratic" I only have 14,800 miles on my 2005 Spider and it just came on at about 1/2 tank of gas.
  2. wbt
    wbt Karting
    Nov 28, 2014
    234
    New Zealand
    Wayne
    Quite common. There's a leak in the evap system somewhere, like you say the gas tank cap is one cause, but also the array of hoses and valves above the tanks leading to the carbon filter and plenum can also develop leaks. Most frequent cause outside gas cap is the o-ring seal under the 4 roll over valves. The seals are cheap but the valves are very expensive if you crack them twisting them out. Unfortunately the plastic gets brittle over time so breakage is common. Also could be fuel pump seals, pump filler hose or any of the associated clamps. There are a lot of parts in the system, the best way to find the leak is to inject pressurised smoke into the system and see where it eventually leaks out.
    Periodically while driving the ecu actuates a valve seal to close the system and measures the pressure developed inside the tank to check for leaks. If it's lower than expected the light comes on. It can be random when it does the test so a light doesn't necessarily align to a time or way of driving. More of a nuisance warning unless you smell gas leaks then you need to fix asap.
  3. LeoExotic
    LeoExotic Karting
    Nov 29, 2003
    163
    Manalapan, NJ
    Leonardo
    I ended up resetting the light. Drove more than 100 miles with no cel. I took the car to NJS inspection and failed because the read out said "not ready" I'm assuming the dme didnt cycle yet to check. I gyess I'll have to drive around with no inspecrion untill it cycles again.
    Sent from my LG-H932 using Tapatalk
  4. 24000rpm
    24000rpm F1 Rookie
    usually a rubber seal in the evap system.
    but I've seen a carbon canister leaking like hell
  5. LeoExotic
    LeoExotic Karting
    Nov 29, 2003
    163
    Manalapan, NJ
    Leonardo
    I have a smoke tester. Is there any tutorials on how to test the F430 for leaks?
  6. Hawaii Brit
    Hawaii Brit Karting
    Dec 16, 2018
    166
    Vancouver, WA
    Had same error. Turned out to be a broken fuel cap. Wasn’t locking closed. Just see if your cap locks as you turn it to the right. Dealer quoted me $600 for new cap. Found one at a Ferrari breakers in Sacramento for $140. Light gone. Dealer said the system recycles after 4 drives.
