paint problems | FerrariChat
paint problems
Discussion in 'Technical Q&A' started by alan mercer, Jan 23, 2007.
  1. alan mercer
    alan mercer Rookie
    Nov 3, 2006
    6
    highlands,scotland
    alan mercer
    I have owned my 2000 360 modena since august 2006, and I have noticed small pimples under the paint, around the front of the bonnet(hood) and also the top of the front wings. I live in the highlands of scotland ,where my car lives under a custom car cover- snow,wind & frost -no alternative- too wide for my garage. Does anyone have any suggestions ,on what could be causing the problem , and if there is a fix,apart from a paint job
  2. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Alan,
    Its pretty impossible to say for sure what your problem is without seeing the car but it may be micro blistering this can be caused by water penetration or rust.
    You will need to take the car to a good paintshop and see what they say and yes it will need to be repainted.
    Hope this helps.
    Regards,
    Phil.
  3. extreme_detail
    Nov 23, 2006
    8
    scotland
    mike fraser
    hi alan if you like i can come up and have a look at it if you like as i`m not that far away
  4. Jackmb1
    Jackmb1 F1 Rookie
    Dec 27, 2005
    3,329
    This could be moisture building up under the car cover, since it stays covered all the time.
  5. Ed_Long
    Ed_Long Formula Junior
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    Alan:
    I agree with Jack, you are probably getting some moisture under that cover from condensation. I occasionally see that here in Oregon where it occasionally rains also. You need to widen your garage and get a new paint job.
    Ed
  6. alan mercer
    alan mercer Rookie
    Nov 3, 2006
    6
    highlands,scotland
    alan mercer
    I will give you a ring in march,and take up your offer - I have your business number Cheers Alan
  7. alan mercer
    alan mercer Rookie
    Nov 3, 2006
    6
    highlands,scotland
    alan mercer
    Thanks for all your reply's -It does look like I will have to find a bigger garage - cover seems to be the problem
  8. extreme_detail
    Nov 23, 2006
    8
    scotland
    mike fraser
    i remember a mate of mine went off to oz for a year and put a cover on his car and when he got back the roof needed painted
  9. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,681
    NJ
    Peter
    I had the same issue with a Porsche that was parked with a outside covered for an extended period of time. It's probably less damaging to leave it uncovered, though the only real solution is a garage.
  10. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    What kind of cover do you have?
    Some covers are better than others; some actually won't let water in, but allow air to breath out.
    The one I have is made with "Technalon 2" material.
    Another temporary solution may be to put-up one of those temporary garages that they advertise in the back os Auto magazines.
