News
Panerai Ferrari Rattrapante FER00010 Box/Papers, MINT
Discussion in 'Ad Archives' started by Blue4reF1, Oct 25, 2016.
  1. Blue4reF1
    Blue4reF1 Formula 3
    Jun 12, 2007
    1,452
    Plantation, FL
    Blake Simon
    #1 Blue4reF1, Oct 25, 2016
    Individually Numbered, Limited Edition of 500 pieces
    Case Size - 45mm
    Comes with the following straps:
    - Genuine Panerai Black Alligator with red leather backing on OEM Panerai deployment clasp
    - Genuine Panerai Black Rubber Strap
    - HORUS Red Camouflage Rubber Strap with PVD Black Buckle
    - HORUS Navy Blue Camouflage Rubber Strap with Brushed Silver Buckle
    List Price: $14,600.00
    Asking: $5,750.00
    Please PM me with any further questions
    Case Material: Brushed and Polished Solid Silvertone Stainless Steel Case and Screwdown See-Through Exhibition Caseback Case Dimensions: 45mm (1.77") in Diameter, 16.8mm (0.68") Thick
    Bezel: Brushed Solid Silvertone Stainless Steel Bezel with Tachymeter Scale Inner-Bezel
    Movement: Precise Swiss Made Panerai OP XVIII Self-Winding Automatic Mechanical Movement, 13 Lignes, 31-Jewels, Glucydur Blance, 28,800 Alternations/Hour (Twin Column Wheel for the Chronograph Functions, Incabloc Anti-Shock Device, 42-Hour Power Reserve, Cotes de Geneve Decoration on the Bridges, Oscillating Weight Engraved with the Prancing Ferrari Horse, Blued Screws, Chronometer Certificate C.O.S.C.)
  3. jimpo1
    jimpo1 Two Time F1 World Champ
    Silver Subscribed Owner
    Jul 30, 2001
    22,654
    Dallas, TX
    Jim E
    That's the best looking Ferrari watch that Panerai made!
    You might want to recenter the second hand on the stopwatch, it should be at the 12:00 position. It's a pretty simple procedure;
    1. Pull out the crown to stop all watch functions (un-screw if necessary)
    2. Press the top pusher until the second counter is in the position you would like it to start at (typically this is the 12 o’clock position, however you can choose to start it at any position on the watch)
    3. Push (or screw) the crown back into position and test the chronograph. It should now start at and return to the position you chose.
  4. Blue4reF1
    Blue4reF1 Formula 3
    Jun 12, 2007
    1,452
    Plantation, FL
    Blake Simon
    Thank you! Have had it for many years - its a great piece!
  5. Blue4reF1
    Blue4reF1 Formula 3
    Jun 12, 2007
    1,452
    Plantation, FL
    Blake Simon
