Parking light problem on 360 | FerrariChat
Discussion in 'Technical Q&A' started by defros, Sep 11, 2008.
  1. defros
    defros Karting
    Aug 25, 2004
    135
    Beverly Hills
    Dima
    I searched the threads and was not able to see the same problem. When I turn on my lights, the rear parking lights do not go on. The parking lights on the drivers side work, but the passenger side does not. I checked the fuses, bulbs and the relays, but they all seem ok. What can be the problem?
  2. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    I am going with bulb. It may look ok but unless you used an ohm meter you can't be sure. Even then, there is some doubt unless you pulled current.
  3. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    It may also be the earth wire to the tail light which is not properly in contact with the body or tail light, I had an intermittant problem and the auto electrician said it was a faulty earth due to a loose coonection.
  4. defros
    defros Karting
    Aug 25, 2004
    135
    Beverly Hills
    Dima
    Could 1 bad bulb cause so many other lights not to work?
