PARKING light switch repaired ! | FerrariChat
Discussion in 'Boxers/TR/M' started by Juri, Dec 26, 2010.
Do you like this post?
  1. Learned NEW useful stuff
  2. Did NOT learn anything new
Multiple votes are allowed.
Results are only viewable after voting.
  1. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #1 Juri, Dec 26, 2010
    Dear Ferraristi,
    Earlier this week, I have noticed that the “parking light” switch in the central console of my
    Testarossa is “on” and a green light is lit up on the dashboard… I tried a couple of times to depress it, but it would not stay disengaged in the “off” position (would not stick in when you press on it).
    To figure out what was wrong with it, I took the central console apart step-by-step to get to the body of that switch, as shown in the attached pictures:
    1) Turn the battery switch off
    2) Unscrew the bolt positioned on the bottom of a tray with a small hex-wrench
    3) Take out the tray
    4) Unscrew the screw in the middle of the bridge using a small Phillips-type screw driver
    5) Gently push the central switch panel assembly plate forward and up from below
    6) Remember to put towels on the leather trim to protect it
    7) Disconnect the switch contacts
    8) Unscrew a mounting ring of the switch underneath the panel assembly. Be carefull not to drop the plastic ring and an aluminum washer into the mid-console
    9) Use a small flat screwdriver to gently depress the “click-in” corner pins of a rectangular plastic trim part and push it up from under the panel assembly plate
    10) Push the body of the switch up through the panel assembly plate
    11) Using a flat screwdriver or a scraper carefully disassemble the switch body and pull it into two parts. Be careful not to lose the spring, which will literally “jump out” when you will be pulling the body of this switch apart.
    12) Observe a “tilting arm” containing a 1mm pin that should be positioned inside the “on-off” latching switch mechanism. The mechanism is similar to that used in click “on-off” ball pens. Push the retaining pin into the body of the switch using a small nail and gently tap it out
    13) Pull the “tilting arm” out and inspect it. As seen in the picture, it was slightly bent in the “neck” containing a 1mm pin, that should be positioned inside the “on-off” latching switch mechanism.
    14) After straightening the “tilting arm” in the neck region using small pliers, all parts of the switch were assembled back together, as shown in the attached pictures.
    15) The switch body was placed back into the central panel assembly.
    The whole procedure including time to figure out how to disassemble and fix the switch took no more than 30 min.
    If you encounter a similar problem, try to repair this switch yourself before spending lots of $$$.
    I will be glad to answer any questions you may have related to this experience.
    Cheers.
  2. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Great writeup and the pics make it so easy a caveman like me can do it.
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,261
    Mel
    Very informative indeed ! Super !
  4. BigTex
    79,378
    Houston, Texas
    Bubba
    Wow!! Good work!!!
  5. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
  6. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    Thanks for taking the time to post those pics
  7. Hawaii
    Hawaii Formula Junior
    Jan 28, 2007
    847
    Maui
    Emery
    Beautifully done! Thanks for helping many future Fchat guys out! Keep em coming!
  8. marchambault
    marchambault Rookie
    Aug 4, 2011
    20
    Toronto, Canada
    I seem to have the same problem in my 512 TR. The mecanism is the same so It shouldn't be problematic to fix.
    thanks.
  9. dontilgon
    dontilgon Formula Junior
    May 30, 2011
    332
    NY/PA
    Joseph
    Wow great write up.
  10. marchambault
    marchambault Rookie
    Aug 4, 2011
    20
    Toronto, Canada
    #10 marchambault, Aug 10, 2011
    Just checking back in.
    I removed the parking light switch that was stuck in the open position from the dash of my 1993 512 TR. The operation is much, much simpler than in the Testarossa as described above.
    The actual switch in itself is the same so I opened and operated as per the instructions and put it back together. Everything works fine now.
    The only thing you need to remember is that it is more difficult to remove the steel arm and pin (on my 512 TR switch it was anyway) so I had to bend the arm while it was still in the socket, but still worked.
    Cheers,
  11. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Great work there Juri. Thanks for putting it all together.
    P
  12. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Interesting. My switch is in the overhead console. (88.5 TR)
  13. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    Ya done good Juri! Ya done good......Thanks! ;-)
    Complementary Me
  14. Zxgarage
    Zxgarage Formula Junior
    638
    MD/ DC area
    Zack
    Great pics...
    It is amazing how complicate the italians can make a simple task... :)
  15. homestrong
    homestrong Rookie
    Nov 7, 2010
    18
    Hermosa Beach 90254
    Chris Runowicz
    #15 homestrong, Oct 12, 2014
    I have a 93 512TR and the parking switch doesn't latch.
    I've studied the comments/posts on this repair. I've removed the parking light switch ), and now I want to open up the switch itself, to adjust the clip inside.
    But I don't know how to open up this switch.
    I've attached two pics. Any suggestions on how to proceed?
    thanks!
    chris
  16. tvu
    tvu Formula 3
    1,362
    Southern California
    Trieu
    I think if you look at Juri's picture above where the unit is disassembled, you will see there are the clips/plastic tabs(looks like mini ramps)/catch. I would assume the you would need to get multiple flat head screwdriver to push in those tabs simultaneously in order to pull the bodies apart. Those would correspond to the rectangular indents in your pictures.
  17. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    just did the fix today. Needed three hands and 3 flat head screwdrivers
  18. Col. Kurtz
    Col. Kurtz Formula Junior
    Jun 20, 2013
    276
    New England
    Walter E.
    Great write-up!
    Thanks for taking the time to post easy to follow pics.
  19. UpNorth
    UpNorth Formula 3
    Sep 30, 2006
    1,768
    Quebec, Canada
    Francois
    +1!
  20. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    The writeup was excellent. I would add this though, i had great difficulty pushing the panel forward and up on mine. I found it necessary to gently pull the side of the console to allow the panel to come up.
  21. chabch
    chabch Formula 3
    Aug 15, 2010
    1,075
    France
    Christophe
    Awesome writeup!
  22. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    444
    Singapore
    BCChoo
    I followed the write up step by step and got the switch fixed ! Great write up ! I later realized that the switch has a small light bulb but the light will never on. I guess the bulb is blown. Can anyone tell me where can I get the replacement bulb ? Thank u !
  23. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    normaly every bosch service has this
  24. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    As I recall that's a universal switch--rather than lighting at the switch Ferrari wired it so the light on the main instrument console illuminates (only) and not the switch. Some have decided they wanted the switch to light so they ran a ground wire to the (-) side of the bulb, but I don't believe that's how Ferrari intended it.
  25. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Thank you Tim for the information ! Ok so the bulb should not be on/off on the switch I will leave it as it is .
