Parking lights not working on 360 | FerrariChat
Discussion in '360/430' started by defros, Sep 13, 2008.
  1. defros
    defros Karting
    Aug 25, 2004
    135
    Beverly Hills
    Dima
    I searched the threads and was not able to see the same problem. When I turn on my lights, the rear parking lights do not go on. The parking lights on the drivers side work, but the passenger side does not. I checked the fuses, bulbs and the relays, but they all seem ok. What can be the problem?
  2. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,167
    Wash DC area
    Robert
    Ground??
    Robert
  3. defros
    defros Karting
    Aug 25, 2004
    135
    Beverly Hills
    Dima
    If it is a problem with the ground, would that be at the battery or someplace else? The brake lights work fine, just the parking lights are not working.
  4. masar
    masar Formula 3
    Aug 19, 2007
    1,367
    Czech republic
    Petr
    Try to check contacts, maybe there is some dirt or oxidation. Buy some spray for electric contacts and spray it all over the connectors.You have to do it few times and wait minute between. I had similar problem with one tail light and this helped.
  5. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    Had a similar issue on my 550 with the reversing lights. Thought it was the gearbox switch which was dead, but it turned out to be a bad contact with a wire harness in the fuse box.
  6. defros
    defros Karting
    Aug 25, 2004
    135
    Beverly Hills
    Dima
    I will try using contact cleaner, but I doubt that is the problem. If it was a loose connection, wouldn't all of the parking lights stop working?
  7. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Check the bulbs and fuse with an ohm meter. They can appear good but actually be failed. Note: this is more likely to happen in the bulbs than fuses.
    If they are al good, check for voltage at the socket. Use the motor as a ground point. Then check it across the socket. That will tell you if you have a ground problem or no power.
  8. defros
    defros Karting
    Aug 25, 2004
    135
    Beverly Hills
    Dima
    Great advise, I will try it.
  9. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Let me know the results and I will make a suggestion about the next steps. This too can be solved.
