430 - Part number for decklid strut bracketB | FerrariChat
430 Part number for decklid strut bracketB
Discussion in '360/430' started by Dennis_said, Mar 8, 2023.
  1. Dennis_said
    Dennis_said Rookie
    Jan 24, 2021
    34
    Dennis Nguyenkhoa
    Hello all! Successful fuel pump operation. However, I did manage to break the bracket that holds the deck lid’s strut arm on driver side to the ball joint. Can anybody point me in the right direction for purchase?
    Thank you !
  2. Qavion
    Qavion F1 World Champ
    14,299
    Ian Riddell
    Not sure what I'm looking at here... Is it some kind of locking collar/ring?
    The only "bracket" I see is item #12
    https://www.eurospares.co.uk/Ferrari/430/F430_Coupe_(USA)/PartDiagrams/0113/ENGINE COMPARTMENT LID
    Do you have a photo of the good side?
    The strut itself isn't so expensive. P/N 65855000. You may save a couple of dollars if you can find a sachs/stabilus substitute for engine lid strut. I could only find one for the frunk lid on the forum... i.e. SG404018. Length and force may be different on the engine lid.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Yes that is the lock ring
    Qavion likes this.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    When you take that ring on or off, use a pair of spring loaded external circlip pliers, it will save damaging it and a lot easier
  5. Dennis_said
    Dennis_said Rookie
    Jan 24, 2021
    34
    Dennis Nguyenkhoa
    Yah! I should’ve been more careful.
    Locking collar seems right. As a temporary solution I tightened the broken piece (a portion of it bent and broke off). With this process I managed to wrap the collar around the strut to lock it but hoping to find a replacement to get on there.
    The picture that is found is more of a bracket and too big. Thanks all for the help. Maybe it’s not something that can be purchased individually.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Look on sgs-engineering.com in the uk, they make these struts so probably have these clips, worth an e mail
    Qavion likes this.
  7. Qavion
    14,299
    Ian Riddell
  8. Dennis_said
    Dennis_said Rookie
    Jan 24, 2021
    34
    Dennis Nguyenkhoa
  9. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    919
    Georgia
    Mark Gronsbell
    I have seen that clip on every strut I have replaced. It should be on both ends of the strut where it goes over the receiver ball. Is it not on the new strut? If not salvage one from the old strut. They pull back slightly to release the old strut from its ball mount.
  10. Qavion
    14,299
    Ian Riddell
    He wasn't changing the strut ;) See post #1.
  11. Doctor Mark
    Dec 15, 2005
    919
    Georgia
    Mark Gronsbell
    I realize that that he was not changing the strut. However, to get the side panels off to access the fuel pumps (if it is like a 360), you have to remove the struts from their mounts. I suspect that this is when the issue occurred. The part in his hand looks like the locking spring that secures the strut to the ball mount on the car. Either get a new strut which is not very expensive or buy a cheap strut and harvest the spring.
