355 - Part porn (secondary cat bypass) | FerrariChat
355 Part porn (secondary cat bypass)
Discussion in '348/355' started by jeffdavison, Feb 7, 2020.
  1. jeffdavison
    jeffdavison F1 Rookie
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Jasonberkeley, phrogs, marioz and 4 others like this.
  2. marioz
    marioz Formula 3
    Nov 21, 2003
    2,007
    Cedar Mills,Ontario
    Mario
    Let's see it installed!
  3. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    it’s a nice piece.
    but never understood why the flange connection on one side and not the other?
    i bought nouvalari ypipe at probably 1/3 the cost.
  4. jeffdavison
    2,544
    Suwanee Georgia
    Jeffrey Davison
    #4 jeffdavison, Feb 9, 2020
    probably for ease of installation is my guess.... this was an impulse buy, cost was just a bit higher than the Fabspeed, so I justified the purchase. Seen the Nouvalari Y pipe for the 2.7. Mine is a 5.2. Little if any performance gain I imagine, but I'm a sucker for eye candy, if I can afford it.
  5. bcar1
    bcar1 Karting
    220
    NYC/NJ
    Bob
    definitely for installation- the fabspeed & Larini are single piece and require removal of the primary cats which is a pain.
  6. jeffdavison
    2,544
    Suwanee Georgia
    Jeffrey Davison
    I think I'm going to give it a Swain Tech "White Lightning" ceramic thermal coating to help keep temps in the engine compartment down with the more exposed pipe length.
  7. Culprit
    Culprit Formula Junior
    480
    Santa Ana, CA
    Ian
    I'm planning on getting the 'Spiral type' Kreissieg Y-pipe for my 2.7 car and doing the same coating.
    Anyone have an idea if the secondary cat delete affects California smog tests? The exhaust only runs through the Y-pipe at higher RPM when the valve is open, correct? Is this measured during smog testing?
  8. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    I don't know all the details of California emissions testing but thought I read they do a visual inspection of components. Having secondary cats replaced with a cat delete pipe would likely fail you if that is the case.
  9. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    California requires that all OEM components be in place; they can even fail you for an aftermarket CAT. Whether or not the test center would notice on your particular car, I couldn't say.
  10. Culprit
    480
    Santa Ana, CA
    Ian
    Got the 2.7 version Y-pipe last week. I'm in Japan for an assignment (yes I know) and so got a good deal on the price + shipping. I'll have it ceramic coated and painted in black so it will match nicely in the engine bay.
    jeffdavison and Qavion like this.
