PARTS: 308, 328, Mondial, Testarossa, 246 DINO, 365 DAYTONA - updated 12-6-13 | FerrariChat
Discussion in 'Ad Archives' started by i-velocita, Dec 6, 2013.
  1. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    #1 i-velocita, Dec 6, 2013
    Please PM me with interest/questions. Thanks...Jim
    EXTERIOR/BODY
    -Ferrari fender shields, genuine cloisonné, finest quality reproductions, NEW @ $285/pair (fit Mondial/308/328/348/355/360/430/456/550/575/599/612/California,others)
    -308 washer fluid reservoir with pump and lid @ $165
    -308 hood (non QV) silver, excellent @ $500
    -328 doors, rust free, complete w/glass, mechanicals, electricals @ $950 each
    -308 gravel guard (fender liner panel) left front @$50
    -308 gravel guard (fender liner panel) right front @ $50
    -308/328 undercar access panel @ $45
    -308 left shield, P/N 600770700, NEW @ $35
    -308 right exterior door handle @ $75
    -308/328 gts rear quarter glass, L&R @ $150 ea
    -308/328 gtb rear quarter glass, R @ $150
    -308/328 gts rear quarter window gaskets, L&R @ $50 ea
    -308 left catalytic converter cooling duct @ $50
    -308/328 front trunk latches @ $35 each
    -308/328 rear deck lid latches @ $35 each
    -308/328 rear deck lid hinges @ $45 each
    -308 passenger door latch assembly @ $150
    -308 front bumper, U.S. @ offer
    -308 front grille, U.S. @ $600
    -308gt4 rear muffler shroud/grille @ offer
    -Testarossa rear grilles @ $ offer
    -Mondial rear quarter panel, right @ $500
    -360 OEM factory fender shields, L&R @ $550/pair
    INTERIOR
    -308 gts QV sun visors, L&R @ $125/pair
    -308 gtb sun visors, L&R @ $65/pair
    -308gt4 leather door panels, black @ $700/pair
    -308 seats, tan @ $1800/pair
    -308 seats, tan w/new correct leather @ $2800/pair
    -88 Ferrari Mondial dash windshield vent trims @ $100
    -308 fiberglass interior rear trunk pieces, left, right and center @ $50 each
    -308 complete rear trunk carpet set, OEM Ferrari @ $200
    TOOL/JACK
    -Ferrari wrench, 9/8mm, “Ferrari, KRAVM” on handle, NEW @ $50
    -Ferrari flat/standard blade screwdriver, red handle, 7.5” long, NEW @ $150
    -308/328/Mondial/Testarossa tool kit, excellent @ $500
    -Testarossa ratchet with elbow and extension @ $200
    ENGINE/IGNITION
    -308/Mondial (4) camshafts @ offer
    -308 distributor cap bases, front & rear @ $65 each
    -308 Cavis plug wire set @ $100
    -308 spark plug extenders, 8 @ offer
    -308 emissions equipment for carb car, smog pump (w/upper bracket, heat shield, tube), charcoal canister, vacuum sphere, valves, hoses, air injection rail @ $675/all
    -308 smog pump lower bracket @ $150
    -308 engine crank shield @ $50
    -308 crankshaft damper/pulley @ $250
    -308 rear header, 2 @ $400 ea
    -308 catalytic converters (pair from 81 gtb, empty) @ $50/pair
    -308 fuel crossover pipe @ offer
    -308gt4 fuel crossover pipe @ offer
    -308gt4 fuel tank, right @ offer
    COOLING
    -308 coolant pipes @ $65 each
    -308 coolant pipes - long under body @ $125 each
    -308 radiator fan (black plastic) @ $50
    A/C, HEATER
    -308 A/C compressor bracket upper @ $100
    -308 A/C compressor bracket lower @ $25
    -308 A/C dryer, right, includes hoses, temp sensor and t-stat @ $95
    -308 A/C dryer, left @ $50
    -308 condensor @ $75
    -308 heat/AC blower fan assembly, (1) left @ $100
    -308 heat/AC blower fan motors, (2) @ $50 ea
    ELECTRICAL, LIGHTING
    -308 gauge pod wiring harness @ $100
    -308/Mondial remanufactured Bosch alternator, 65A @ $125
    -308/Mondial OEM Bosch starter, 2 @ $400 ea (no core charge)
    -308/Mondial OEM Fiat brand starter @ $400 (no core charge)
    -308/Mondial seat belt relay/ecu (60528200) @ $50
    -308/Mondial relay/switch (112198) @ $75
    -328 right window motor @ $125
    -308 left headlight motor and bracket @ $175
    -308 “slow down cyl 1-4” lens @ $10
    -308 amber right front turn signal lens, OEM Carello – NOT reproduction @ $100
    -308 fender parking light lens w/gasket 2 @ $25 ea
    -308 radiator fan motors @ $85 ea
    BRAKES
    -308/Testarossa brake & clutch pedal box (includes pedals) @ $500
    -308 hand brake lever assembly (2) @ $175 each
    -308 front calipers, (2) L & (2) R @ $250 each
    -308 rear rotor @ $100
    -Testarossa front calipers L&R @ $350 each
    -Testarossa rear calipers L&R @ $350 each
    SUSPENSION & STEERING
    -308 steering column w/anti-theft assembly @ $800/offer
    -308 steering rack clamps/mounts, 2 @ $35 each
    -308 right rear hub assembly @ $350
    -308 right rear hub assembly (needs rebuild) @ $200
    -308 right rear upper control arm @ $200
    -308 right rear lower control arm @ $200
    -308 front sway bar @ $150
    OLDER FERRARI/MASERATI
    -Daytona grille @ $1000
    -Daytona right door @ $1000
    -Daytona window motor and regulator @ $250
    -246 Dino door hardware L&R + misc parts @ $1000
    -246 Dino misc lights @ offer
    -246 Dino air emissions trees @ $550
    -330gtc rear center bumper, headlight trim and door trim @ $1000
    -365gtc/4 right front quarter panel @ $500
    -250gt Lusso windshield, NEW @ $1000
    -Maserati Indy windshields (2), NEW @ $1000 ea
    -Maserati Indy windshield gasket, NEW @ $300
  2. i-velocita
    2,520
    Colorado
    James
    #2 i-velocita, Dec 9, 2013
  3. matumorales
    matumorales Formula Junior
    Jun 8, 2011
    470
    Asunción, Paraguay
    Daniel Morales
    Hello, Jim!
    Any new arrivals to this list?
    Best,
    Daniel
  4. Hejman
    Hejman Rookie
    Mar 13, 2014
    10
    Are you referring to the fuel pump pipe that runs from the fuel pump to the accumulator? If so, I am on the lookout for one fitting an '85 QV. Thanks.
    Chris
  5. i-velocita
    2,520
    Colorado
    James
    I'll post a new list soon Daniel. Thanks...Jim
  6. i-velocita
    2,520
    Colorado
    James
    Chris, the crossover pipe I am referring to is the one that connects the two fuel tanks. Thanks...Jim
  7. Ranzilotti@1scs1.com
    Mar 23, 2014
    10
    New York
    Robert Anzilotti
    just joined Ferrari Chat and don't know how to PM you. i am looking for the front center console tunnel in black for my 1988 328-GTS. i also can use interior and truck carpeting. any ideas?
  8. carguy246
    carguy246 Formula 3
    1,197
    Maryland
  9. BigTex
    79,380
    Houston, Texas
    Bubba
    Jim,
    stradman in the UK is looking for a tool kit, but for a 'glass GTB.
    I don't know if that later roll you have is of interest to him.
    That is a nice roll for $500
    Alan
    I sent him a PM about it.
  10. BigTex
    79,380
    Houston, Texas
    Bubba
    You click on the underlined User Name, and you'll see the option, it does take a few days for new members to be allowed to use it, while we check you out! :D :D
    GAHH and also World Upholstery have excellent carpet sets.
    Check salvage yards at FerrParts or TRutlands for your console...
    Welcome!
  11. i-velocita
    2,520
    Colorado
    James
    Hi Robert,
    Sorry, I don't have the center console piece. I will have a carpet set soon but from a 308.
    To send a PM, click on "Jim400i," then click on "send PM to jim400i."
    Thanks and best...Jim
  12. i-velocita
    2,520
    Colorado
    James
    Thanks Tex!
    That was a nice kit. It sold right away.
    How have you been?
    Best...Jim
  13. BigTex
    79,380
    Houston, Texas
    Bubba
    I got unemployed, so I just sit around and drink coffee in the mornings....
    Ok, he offered a great price for one of mine so OFF it goes into a 'glass car!!
    I'm honored to help..
    I'm selling my 1976 #20405.
    Maybe we should chop it to bits, and make some real money????
    Lady V. walked out also, funny how few of life's troubles will bring that on....
  14. i-velocita
    2,520
    Colorado
    James
    Sorry to hear about your troubles Tex. Enjoy that coffee now. No doubt you'll be busy at work again soon. What is the unemployment rate in Texas, 6%?
  15. BigTex
    79,380
    Houston, Texas
    Bubba
    It's way low, with a lot of unskilled labor absorbed by the oil boom.
    I have been doing an engineering services inspection thing, but now between projects.
    Maybe I should go surfing in Galveston and meet some college girls on Spring Break.
  16. i-velocita
    2,520
    Colorado
    James
    Yes, drink coffee in Galveston. ;-)
  17. BigTex
    79,380
    Houston, Texas
    Bubba
    Tuesdays at the Black Pearl Oyster Bar, the shrimp enchiladas are served by a blond Moldavian girl, named Tatiana.....
  18. i-velocita
    2,520
    Colorado
    James
    Sounds exotic! Although she might be Russian soon. ;-(
  19. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #19 Wade, Mar 24, 2014
    Sounds like a line from a movie script (Film Noir).
  20. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Jim, I'm looking for a windshield washer tank with pump for a Mondial 3.2, one hole on top (no sensor).
    Thanks!
  21. i-velocita
    2,520
    Colorado
    James
    Hi Wade,
    Sorry, just have reservoirs for 308 and 328 at present. I'll let you know if I find one.
    Best...Jim
  22. Ranzilotti@1scs1.com
    Mar 23, 2014
    10
    New York
    Robert Anzilotti
    Thanks for the info. I guess i didnt check out yet since i can not PM. i will be patient.
  23. Ranzilotti@1scs1.com
    Mar 23, 2014
    10
    New York
    Robert Anzilotti
    Thanks and one day i will be able to PM . i guess as soon as they check me out, according to BigTex.
  24. i-velocita
    2,520
    Colorado
    James
    I think you should be able to PM by now Robert. Contact me anytime. Thanks...Jim
  25. BigTex
    79,380
    Houston, Texas
    Bubba
    That's HER!!!!
    Thanks, Wade...I count my Ferrari internet friends among the many blessings in my life.
    Well, yesterday was her day off, the food was good, I got a Parking Ticket from the Meter Maid, when my time ran out...
    I dropped off the Cadillac CTS title to Mom for safe keeping and future Pawn value.
    And went to check on the progress of the restoration of both my speedboat and the 1994 Pontiac 25th Anniversary 6 speed Trans Am.
    It all hit home, when my dear old friend and cancer survivor was waiting on his government check...I palmed him a $20 so he could get his wife some groceries, and I was instantly adjusted in my perspective..
