355 - Parts for Transmission Fluid change - 355 | FerrariChat
355 Parts for Transmission Fluid change - 355
Discussion in '348/355' started by SA Mike, Mar 6, 2020.
  1. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Other than the fluid itself are there any other parts needed for the fluid change ie. washers, part numbers, etc... thanks!
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  3. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Thanks Eric I’ll do that. It was actually for a transmission fluid change btw
  4. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    If nothing is leaking, just fluid.
    there is a filter inside the transmission, I believe it's a metal mesh screen. However, it is unreachable with the transmission in the car.
    If you have any leaks, it would be the perfect time to replace those gaskets on the square panels on the bottom.
  5. Qavion
    Qavion F1 World Champ
    14,272
    Ian Riddell
    Although some folks still use copper washers, the OEM replacement washer has rubber seals. You'll need one for the top and one for the bottom, P/N 144810 (expensive).
    You'll need the usual stuff to get the car in the air to access the lower (drain) plug. I recall a 10mm hex key is required for this plug.
    Some folks attack the upper (refill) plug from the top. For this you'll, need a 13mm hex key socket with a very long extension. 2 feet or maybe longer. Wrap the engine compartment crossbrace with rags to prevent scratching. For refilling, I use a funnel with a long clear plastic tube.
    You'll need some transmission fluid, of course. 5 litres. I use Redline GL5 75W90NS. The plug has a built-in dipstick.
    You'll need a torque wrench. 50NM for the lower plug, a little less is good for the top one because sometimes it's a pig to get loose.
  6. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I knew that.. sorry. 348 but its the same process. Good luck, let us know what oil your using and how it works. :)
    https://myferrari.page.tl/348-Gear-Oil-Change.htm
  7. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    thanks Ken!
  8. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Thanks Ian! I got the Redline as well.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    It's funny that for the engine oil sump they also show a Dowty washer but list a copper washer as an alternative. And for the oil tank they list only a copper washer. Go figure.
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I know folks hate hear oil discustlion but I just reviewed gear oil tests with result data, pictures and videos of the tests, the redline did not well shall we say but the amsoil severe gear I use was at the top but it's horrible in my car. If the Spirax gl5 does not work I'll try gl4 as the gear box looks like all spur gears anyhow, I don't get why gl5 but there must be a reason.
    Some cars like oil x and others like y just depends on gaps and tolerances such as it is.
    Good luck!
    Sent using FerrariChat.com mobile app
  11. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    I read something in another thread recently..
    when doing the transmission oil, there is a washer to replace that cost $50 or something like that..
    but there is a replacement option for $2
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  13. Qavion
    14,272
    Ian Riddell
    Did you also get the friction modifier? I normally add a couple of capfuls, but as I recently fitted a new main shaft and 3 sets of new gears, I had to add a whole bottle on my last change as per Redline recommendations.
  14. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    I just switch from red line to spirax. I think it's shifts a little better.
    MAD828 likes this.
  15. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    I used Motul 300 LS 75w-90. Pretty smooth
