Parts ID help requested... | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by TTR, Jun 16, 2021.
  1. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    I came across a 16" x 5" Borrani wheel with what appears to be partial RW number digits of 0 7 7 stamped on the outer rim edge after the "C.BORRANI 16X5 RECORD" and perhaps manufacturing date code of "9-54" on the inner rim edge.
    It supposedly came off a 250 GT Europa 5+ decades ago, but based on above details, could that be correct application and if yes, which other models it might've come with ?
    Also, a 3-carburetor Air Cleaner assembly with FISPA tag Tipo 2231.01 supposedly from SI 330 GT.
    If correct, which other models it might fit or be accurate for ?
  2. lancia
    lancia Formula Junior
    519
    RW3077 (16 x 5K) - application is yes 250 Europa GT. (My notes say TR front application as well, but not sure if that is accurate, or which TR)
    christc and TTR like this.
  3. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    Wow, that was fast. Thank you, Sir.
    If anyone else has additional information, it will also be greatly appreciated.
  4. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,844
    Timo: RW 3077 is the correct front wheel for a 250 Testa Rossa (Pontoon style).
  5. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    Thanks Dyke (and again "lancia"),
    It appears to be in pretty good shape (with nice "patina"), i.e. not much oxidation on aluminum or curb rash on the bead edges.
    I guess it'll probably be closest I ever come to "having/owning" a "Pontoon" 250 Testa Rossa (or Europa GT). :)
    So the air cleaner housing still remains a bit of mystery ?
  6. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,844
    Timo: the air cleaner is from a Series 1 330 GT. It should fit any Tipo 209 motor due to the carb spacing, but the later cars have different style air cleaners.
  7. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    Dyke, thank you.
  8. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    961
    Australia
    howard pigdon
    Timo I will photograph the tag for you tomorrow
    TTR likes this.
  9. daytonaman
    May 1, 2007
    961
    Australia
    howard pigdon
    before anyone says anything I know the nylocks are incorrect despite thats what Maranello supply
    TTR likes this.
  10. Rifledriver
    34,103
    Austin TX
    I was not aware until just recently the old nuts were made by LOBO and they have gone out of business.
  11. daytonaman
    May 1, 2007
    961
    Australia
    howard pigdon
    Timo heeres the tag on my car -- different nos.
  12. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    Thanks Howard !
    So what you’re saying is that even if components, hardware or parts are supplied by Factory authorized/official network supplier, it doesn’t necessarily mean the items are authentic or correct. :eek: ;) :rolleyes:
