***Parts needed for a Timing Belt & Valve Cover Gskt replacement** | FerrariChat
Discussion in 'Technical Q&A' started by christopher, May 20, 2004.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello Fellow "F"-Chatters,
    Was wondering if anyone would be so kind as to inform me as to what parts will be needed for a Timing Belt and Valve Cover Gskt replacement, aside from the obvious. i.e 2-ea Timing Belts and 2-ea. Valve Cover Gskts., what else might be needed?
    I'll be shopping around for parts tomorrow, and would appreciate a shopping list. This Memorial Day weekend is when I attempt the service. I read a nice tread on the above subject by Ric Rainbolt, and thought I'd attempt it myself. By the way during the tread he often refers to "PM" and PM 1-4, what's PM?
    Thanks, Chris.
  2. Steve Magnusson
    25,145
    What year/model/version? (Why isn't this in your Profile!)
    PM = Top Dead Center
    PM 1-4 = Piston #1 (and Piston #4) are at Top Dead Center
    There's also a PM 5-8 mark on the V8 flywheel.
  3. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Are you just changing the timing belts, or are you attempting to perform a 30k maintenance?
  4. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Thanks Steve, It's a 1979 308GTB produced in June of 79.
    Thank you very much.
    Chris.
  5. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello Dave, I just wanted to change the belts on valve cover gskts on my
    1979 308GTB produced in June-(if that makes any diff.)
    Thanks,
    Chris.
  6. Steve Magnusson
    25,145
    Chris -- you got 2 out of 3 -- what about version? US?
    As Dave J. requested, it would help to know what you're really trying to do. For example, if things are fairly fresh miles/time-wise, but you've got a leaking camcover flat gasket, then I wouldn't mess with removing the camshafts or replace the various lip seals. On the other hand, if you want to do the "whole" 30K thing, I think the list is something like:
    Belts
    Tensioner bearings
    Camcover flat gaskets (both sides)
    Camshaft lip seals (4 seals total, but comes as a set now under a single PN IIRC)
    Distributor Mount flat gaskets (2)
    Distributor lip seals (2)
    Distributor Shaft o-rings (2)
    Small round camcover flat gasket at the undriven end of front bank exhaust cam area (1 for US, 2 for non-US I think)
    Air Pump lip seal (1 for US version only, not used on non-US version)
    If you need to rephase the cam drive sprockets then you'll need the o-rings (2) -- but I wouldn't mess with that unless the cam phasing marks were significantly off.
    I'd probably also replace the 2 ball-bearings in the AC idler pulley if it has been a lot of miles/years (but that's not required).
    Others -- please speak up, correct, edit -- the 308 stuff that I used to know is slowly getting squeezed out of my head by TR stuff ;)
  7. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Valve clearance should have been checked at 15k, and again at 30k.
    So if you intend to do the recommended 30k service, I would include valve shims to Steve's list.
    Good Luck!
  8. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Would all this above still apply??
