Parts needed | FerrariChat
Parts needed
Discussion in '206/246' started by omgjon, Apr 6, 2016.
  1. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I'm working on the 206 SP and I'm in need of the following
    A set of 13" wheels
    A set of veglia gauges
    A single arm wiper assembly
    m14x1.25 grade 12 bolts for motor
    Any help is appreciated
  2. racerboy9
    racerboy9 F1 Rookie
    2,650
  3. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,800
    Southern California
  4. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
  5. racerboy9
    racerboy9 F1 Rookie
    2,650
    If you get those original wheels you might contact Marvic wheels in Italy to see if they could make more using them as a sample. I assume they are a cast wheel. They make the GR4 wheels for the Stratos and have a good reputation.
  6. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    So if I'm able to get or have made 13" wheels I will need to change to rear inboard brakes. Anyone out there know how to do this?
  7. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
    Be sure to look into tire availability before you put down big money on custom wheels. Many tire manufacturers do not even make 13" tires any more and it could become very difficult to get tires.
  8. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    You're correct about that. That's one reason I've considered doing 15" wheels with the same design. Much more tire possibilities. Currently 13" tires you have about 2 choices with both being track tires only b
  9. racerboy9
    racerboy9 F1 Rookie
    2,650
    The TB15's are fine on the road. Run them on my Stratos.
    From the Longstone site:
    Michelin TB15
    MICHELIN TB15 FREE DELIVERY
    TB15
    Michelin TB Radials
    13" Rim Size
    Click to View Tread Rim Width*
    (") Alt Sizing Section Width
    (mm) Diameter
    (mm) Price (ex VAT)
    16/53-13 Michelin TB15 5 - 6 175/60VR13 189 536 £173.00
    20/53-13 Michelin TB15 7 - 8.5 225/45VR13 231 533 £205.00
  10. swift53
    swift53 F1 Veteran
    8,334
    E.S.
    Alberto
    Avon has plenty of 13"s.
    Regards, Alberto
  11. swift53
    swift53 F1 Veteran
    8,334
    E.S.
    Alberto
    Jon, you need a racing engineering firm to do the switch over, designing new parts from scratch and a lot of $ for a car that might not be worth the investment.
    You will need to cast new uprights, new brake discs, hats, calipers, half shafts, etc...
    Plus, inboard brakes get really hot, are a pain to maintain...
    I am aware of your seeking purity and originality, but....
    is it really worth it?
    Regards, Alberto
  12. racerboy9
    racerboy9 F1 Rookie
    2,650
    What kind of transmission are you going to mate to your engine? That might help steer your rear brake search.
