Parts Order Help | FerrariChat
Parts Order Help
Discussion in '308/328' started by sltillim, Feb 11, 2020.
  1. sltillim
    sltillim Formula 3
    1,715
    San Diego
    Hi 308 Crew,
    I am about to embark on a serious list of needed fixes and updates on my GT4, Bambina. I got the car back on the road about 7-8 years ago. I got married, divorced and all managed to keep the car, of which has been a part of my family since I was born. I need some help making sure my parts order is correct. I plan on using a mix of vendors, but mostly Superformance UKfor the brunt of it (I’m happy to be convinced otherwise), some Nick’s Forza.
    The projects are:
    Front Suspension Rubber, Rear Suspension Rubber, Quick steering rack, Nick’s direct fire ignition, Shift Shaft seals, oil sump baffle, Valve adjustment, Derek’s updated Cam pulley (round tooth), Clutch adjustment (slipping after replacing cable) – possible replace, Roll Bar, schroth club sport belts, KW V3 coilovers, visual enhancements: front/rear bumper delete (and hidden crash support), front/rear spoiler, fog lamps, LED bulb update, possible new wheels.
    Can you help me validate my parts order and let me know if I’m missing anything…(excluding the nick’s parts). I will also be getting new hardware. I will have threads for individual projects.
    Front Suspension
    A Arm bush (nick's) 8
    Front Torsion Bar 'D' Rubber 2
    Front Torsion Bar Rubber ends 4
    Drop-Link Silent Block Bush 2
    Front and Rear absorber bush 4
    Rear Suspension
    Upper and Lower Outer Rear Wishbone Bush Assy. Set 2
    Rear Torsion Bar 'D' Rubber 2
    Rear Torsion Bar Rubber ends 4
    mix of a-arm shims for alignment F+R
    Steering Rack
    Superformance Quick Rack Kit
    Rack mount Bushings
    Shift Shaft Seals
    Unobtanium seals / rings
    Motor Oil sump gasket 1
    Gearbox sump gasket 1
    Engine and Gearbox plug washer 2
    Valve Job
    Cam Cover Gasket set 2
    Valve Shim Removal Tool 1
    Valve Shim set ?
    Cam Belt Pulley / Belt
    Derek's Round tooth Cam pulley 2
    Continental updated belts 2
    Cam Drive seals 2
    Ignition
    Electromotive XDI Set (nicks) 1
    Alternator Blank Plates 2
    Blank gasket ?
    Starter
    Gear Reduction Starter
    Fuel Filter 1
  2. moysiuan
    moysiuan F1 Rookie
    4,216
    Canada
    Tidbits...There is 1 engine and 2 gearbox plugs that need the copper washers. You should also get an assortment of the metric nyloc nuts, and some lock washers, for the various things dismantled, the old ones won't hold the torque as well when you reuse them. Bel Metric has what you would need. Might be what you meant by hardware. All I know is mid project being short of a replacement nyloc or a lock washers that ran out of steam is a big annoyance.
    sltillim likes this.
  3. moysiuan
    moysiuan F1 Rookie
    4,216
    Canada
  4. sltillim
    sltillim Formula 3
    1,715
    San Diego
    moysiuan likes this.
