I still have a huge stash of parts that I would like to diminish!! Give me a shout if there is anything on this list you would like. [email protected] 416-802-9999 Ferrari 348 parts available - 348 Transmission - 348 Carbon Fiber interior - 348/355 Roof Lamp 134458 - 348 HANDLE/TOP 62219400 - CARBON CANISTER FERRARI 348 TB CARBON CANISTER FERRARI VAPOUR FILTER - FUSE BOARD FERRARI 348 RELAY FERRARI RELAY FERRARI FUSE BOARD - 3.4T Coupe Right Hand Exhaust Manifold - 3.4T Coupe Left Hand Exhaust Manifold - OEM Genuine Rear 17" Alloy(s) - Engine Hood Bonnet Ferrari Rear Hood - ENGINE FRAME FERRARI 348 ENGINE MOUNT FERRARI ENGINE SUBFRAME - Brake Calipers F348 Brake Calipers Ferrari Brake Calipers ATE - Left & Right Hand Rear Suspension Shock and Spring - FUEL PUMP FERRARI FUEL PUMP - REAR HUB FERRARI REAR HUB CARRIER FERRARI REAR UPRIGHT - DROP LINK - AIR CONDITIONING​ COMPRESSOR - Seats - LH REAR QUARTER PANEL - Right Hand Cat - ANTISKID ECU ABS CONTROL UNIT - ENGINE FRAME ENGINE CRADLE - Airbox - Hydraulic Control Station - Pedal Box Assemble - STEERING COLUMN - AIR INLET PIPE ONE WAY VALVE AIR INJECTION PIPE - TB / 2.7 Motronic Front Muffler - HEATER CONTROLS FERRARI 348 HEATER SWITCH PACK F348 CENTRE CONSOLE - Instrument Pod F348 Instrunmen​t Cover Ferrari Instrument Cover - Engine Wiring Loom F348 Engine Parts F348 Engine Wiring Loom - Centre Console Switch Pack Ferrari 355 parts available - Headlight buckets, trim and motors - Engine - Transmission - Doors - Wheels - Transmisson case - switches (door lock, window ect) - entire climate control clutser and airboxes for a 5.2 engine - 348/355 Roof Lamp 134458 - 355 and 360 HYDRAULIC TIGHTENER 157356 - High Flo Cats - 355 EURO LAMP F 157518 - 355 ABS HYDRAULIC ELECTRONIC CONTROL UNIT (BOSCH # 0273004241) - Transmission/Gear Case - Black Brake Calipers Brembo 4 Pots - Wheels (multiple sets) - Left & Right Hand Cats - OEM used Front hood - Exhaust 168977 CAT 129003 BY PASS TUBE FERRARI 355 EXHAUST CATS - RH DOOR MIRROR - REAR BUMPER - DAMAGED REAR BUMPER - FRONT HUB STEERING KNUCKLE FRONT UPRIGHT - (2.7 Motronic) BY-PASS TUBE Y CAT 166580 - Front Wheel 18" - ABS Pump - Pair of Air Filter Boxes - ANTISKID ECU ABS CONTROL UNIT - Power Steering Rack - AIR FILTER BOXES - FRONT HUB FRONT STEERING KNUCKLE FRONT UPRIGHT - DRIVERS & PASSENGER DOOR - THROTTLE BODY'S (both sides) - Manual Gearbox (Fits Berlinetta & Spider) - WATER PUMP - Heater Controls (Cluster) Ferrari 360 Parts Available - Headlights - Engine Block - Transmission both F1 and manual - F1 Pumps - Wheels - Full Bordeaux leather interior and seats - Brembo Brakes - X-Ost exhaust systems - Tubi Muffler - High Flo Cats - 360 Challenge rotors (2 only) - 360 Immobilizer complete with remotes and pin - 360, Front Shock Upper Support/Suspension spacer 000174727 - 360 Rear O2 Sensor - 360 Bonnet Cable 065853300 - 360 and 430 Engine and Gas Cable 65067300, 80412000 - 360 Fuel Lid 0674941100 - Sending Unit 135940 (used on almost every Ferrari and Maserati) - Airfilters - 360 and 430 Hill Engineering's Clutch release bearing flange CRBF360/430 - Bearing 00131-33400-0000 - Small Script Pininfarina 064780500 - 360 and 430 Spider L.H. LATERAL CAPOTE FLAP 06646200 - 355 and 360 HYDRAULIC TIGHTENER 157356 - 360 and 430 RH DOOR LOCK CPL WITH CABLES 069998000 - upper and lower control arms front to back - brake rotors - Brembo calipers - Alternator CS Alternator P/n. 179852 - FRONT HUB 360 SUSPENSION - Upper and Lower Control Arms Front and Rear - AIR FILTER BOX, AIR INTAKE, AIR BOX COVER - F1 Gearbox Power Unit 179533 - WIRING LOOM FERRARI ENGINE WIRING LOOM - DRIVERS DOOR - F1 INSTRUMENT CLUSTER - REAR QUARTERS SPIDER - Modena GLASS LIFTING ELECTRONIC CONTROL STATION 178708 - 360 CS COIL PACKS - Challenge Stradale Wishbone 200940 - EXHAUST MANIFOLDS - PAIR OF ENGINE ECU S O/S and N/S 178765 - SHOCK ABSORBERS ELECTRONIC CONTROL UNIT 175222 - Rear Shock Absorber - 174724 Rear Strut, Rear Damper - A/C CONTROL UNIT AIR CONDITIONI​NG ECU CONTROL - Brake Calipers Brembo 4 Pot Brake Calipers Ferrari 430 parts available - 430 headlight black - Engine block, crank, pistons, cylinder heads - Engine and Gas Cable 65067300, 80412000 - Hill Engineering's Clutch release bearing flange CRBF360/430 - Spider L.H. LATERAL CAPOTE FLAP 06646200 - RIGHT-HAND HEAD GASKET 198927 - LEFT-HAND HEAD GASKET 198928 - RH DOOR LOCK CPL WITH CABLES 069998000 - FLANGE AND PIPE REPLACEMENT SET 000240169 Ferrari 458 Parts Available - Full Engine, crank, pistons, cylinder heads - transmission - exhaust - cats
Looking at the 355 brakes for my 308. Let me know please. Thank you Brian. Pm sent with contact info.
