Passanger vents blow warm air | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by nflpats, Oct 16, 2017.
  1. nflpats
    nflpats Karting
    Oct 7, 2017
    54
    Tobin Tracy
    #1 nflpats, Oct 16, 2017
    My AC only blows cold through the drivers vents and warm through the passenger vents. Not sure if this is a blend door actuator problem or just needs to be reset (read that somewhere)
  2. good2go
    good2go Formula Junior
    Feb 9, 2016
    939
    can you post your control settings.
  3. nflpats
    nflpats Karting
    Oct 7, 2017
    54
    Tobin Tracy
    I had the controls set at the lowest on both sides with the AC button engaged. I also tried the mono button but same results. I tried all vent settings and same warm air on passenger side.
  4. doccharlie954
    doccharlie954 Formula Junior
    Jul 27, 2010
    256
    Had the same problem on my 12 CALI. It would blow hot in middle, then next time blow only under dash, then on passenger side. Dealer replaced module, STILL no luck. Ferrari advised to check grounds, STILL no luck. Only thing that worked was to turn car off for 3 minutes, open doors and let it reset itself. Sometimes it worked sometimes not. Dealer advised that CALI and 458 had this problem. Do I believe it? No, as my 16 CALI does not have this problem. Good luck as I know this is a royal pain in the arse!!
  5. Jaguar36
    Jaguar36 Formula 3
    1,084
    Cherry Hill, NJ
    Dunno if it would be a similar issue, but I had this problem on my BMW and it turned out to be a leak in heat exchanger. As it lost coolant only half of the heat exchanger would get cold and that was the side that fed the drivers side. replacing the heat exchanger and refilling the system fixed it.
  6. nflpats
    nflpats Karting
    Oct 7, 2017
    54
    Tobin Tracy
    I'll try the 3 minute trick. The heat works, just the AC is problematic
  7. mobinakhtar
    mobinakhtar Karting
    Jan 28, 2015
    172
    May be worthwhile to check the Freon levels - In Mercedes, with personal experience, I can tell you that one side blowing warmer indicates low Freon. You can google it and you will see what I am talking about. My analogy is that Cali has Chrysler Audio - Chrysler shared technology with Daimler - it is therefore possible that HVAC gets this "feature" from Daimler-Mercedes setup.
    My other guess would be damper doors that are used to mix air - but usually they would not affect an entire side.
  8. nflpats
    nflpats Karting
    Oct 7, 2017
    54
    Tobin Tracy
    I thought about that as well. I scheduled an appointment already to have freon level checked. Hopefully that will solve the issue
  9. OwenC
    OwenC Karting
    Aug 12, 2017
    62
    My local Ferrari service guy pointed to me a 458 in their garage had the same issue you are experiencing. And he mentioned that problem causing it was a defective electronic module and they are just waiting for the part to come in.
    Hope you can get the issue fixed soon.
  10. mobinakhtar
    mobinakhtar Karting
    Jan 28, 2015
    172
    Its funny - When my 97 e420 showed this symptom (in early 2001), the dealer wanted to replace the blend module as well. An indy that I used to frequent told me about the Freon being low - and blowing warm on one side and cold on the other - and boy was he right!
    http://www.benzworld.org/forums/w210-e-class/1582318-ac-blowing-warm-air-left-side.html
    read the second post.
    Disclaimer though - I know this to be true in Mercedes. But Ferrari........who knows.
  11. Dishon
    Dishon Rookie
    Jun 23, 2025
    1
    Hi guys, I have a 2015 California T the two vents closest to the left blow cold air with the ac on and the two closest to the right blow hot. I've tried refilling the freon and that did not work. Any ideas what I should test?
  12. VII7
    VII7 Rookie
    May 29, 2025
    24
    Fort Worth TX
    If cooling performance is good on the one side and getting hot air on the other, it is likely the heat blend actuator for that side.
    To confirm check if cooling performance is almost normal when engine is cold.
    Willl likes this.
  13. Lee L
    Lee L Rookie
    Apr 21, 2024
    1
    Lee Lowder
    2020 Portofino. I had the same problem, all vents went from A/C to heat. It fixed itself in a few days. Now it's A/C on the passenger, heat on the driver side. Been that way for a week. Tried disconnecting the battery for one minute to try and reset the computer, didn't help. DFeasler wants to tear out the dash to access the duct system, not inclined to go the route without some experience saying that's best.
    Anyone have experience with the actual resolution of this condition?
  14. VII7
    VII7 Rookie
    May 29, 2025
    24
    Fort Worth TX
    That's likely heat blend motor, whether it can be replaced without dash removal will depend on access.
    Willl likes this.
  15. KIV
    KIV Rookie
    Jun 1, 2025
    17
    Istanbul, Turkiye
    Kevin
    My ‘11 Cali is also acting different;
    in auto mode, everything is perfect.
    But in manual mode, even in lowest degree before maximum-low, it blows warm a/c air. (Lets say it has 10 clicks for degree set-up, 1 being cold, 10 being hot.) If you lower it one more click to maximum-low, it blows the coldest (max a/c mode) … one click up, instead of 2 out of 10, it blows warm like it is at 6th or 7th…
    any idea?
