Passeneger door not opening from outside | FerrariChat
Discussion in '360/430' started by russomanno, Jan 27, 2015.
  1. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    I've had this issue for over a year now but haven't had the time to fix it...
    The passenger side door opens with no issues whatsoever from the inside, but from the outside the only way to open it is if you pull the handle quick and hard. Any idea if there is any adjustment? Or is it a stretched cable or something? Any idea as to why this would only happen from the outside? Thanks
  2. F430giallomodena
    F430giallomodena Formula Junior
    Mar 2, 2012
    910
    Lugano, Switzerland
    common issue for 360/F430, it's the cable, very easy to swap , my F430 had same problem once.
  3. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    I had a similar problem, but I believe mine actually resulted from a broken cable or cable fitting (my exterior handle wouldn't work at all - just the interior one). I had my mechanic take the door apart and replace the cable system, I think. Probably cost me about $500.
    But, yes, it's a common problem. Comes with age I guess.
  4. Ricambi America
    Ricambi America F1 World Champ Sponsor Owner
    Dec 7, 2003
    16,451
    Winston Salem, NC
    The cable is no longer offered as a discrete spare. It comes with the complete latch assembly:
    Ferrari Parts : 69998000 RH DOOR LOCK : Ricambi America
    The good news (if you can consider it good news...) is that the new style cables and latch seem to be holding up quite well over time.
  5. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    +1, this is what my trusty mechanic told me as well, and that's why we had to replace the whole assembly. But, I look at it like an upgrade, and not just a repair. Seems to be working well - waiting for same problem on driver's side though...
    Thank god there's only two doors!
  6. Ricambi America
    Dec 7, 2003
    16,451
    Winston Salem, NC
    That is a refreshing perspective - for real! Masr Quattroporte owners get to deal with all four window regulators failing. Yuck.
  7. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    Yikes that's an expensive part! Maybe I can find something used somewhere.
  8. jpk
    jpk Formula Junior
    Oct 29, 2012
    803
    Los Angeles, CA / Henderson, NV
    You might get luck and find it just needs adjustment. Have your mechanic take a look.
  9. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,540
    Charleston, SC
    Curt
    Bingo. Check the threaded adjusters.. then replace it if needed.
  10. f360nh
    f360nh Karting
    Apr 12, 2014
    210
    NH
    John Q.
    It's usually the cable getting looser and if it's not snapped it will just take an adjustment. I've had to do it on mine, pain in the ... You need to take the inner door panel out and then there's a way to work your way blindly into the upper corner of the door, close to the latch mechanism. There may be other ways but this worked for me, I think the adjustment is now towards the end of the cable so if there's anymore give over time I will need to replace it.
  11. derekmines
    derekmines Formula Junior
    Dec 12, 2013
    284
    Melksham, UK
    Derek
    Mine was just a small plastic part that needed replacing, cost me about $1 for the part which was
    65700900
    Once replaced my passenger door now opens from the outside as well as the inside!
  12. randomlambo
    randomlambo Formula Junior
    Feb 3, 2013
    379
    RI & MA border
    DT
    That part is relevant when not opening from the inside...the inside not opening issue is a lot easier to fix than the outside from my experience.
  13. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    Most ridiculous fix ever... So I decided after suffering for about a year to start taking my door apart to fix the issue. So after I take out the first screw from
    Inside the car I'm like wait a second... Wonder what these two screws do (see pic) I tightened both as they were both loose... And boom, it's fixed... Seriously? Are those adjustment screws or something?
