Passenger Airbag Dash Cover Removal | FerrariChat
Discussion in '456/550/575' started by Jason T. DAmore, May 30, 2012.
  1. Jason T. DAmore
    Jason T. DAmore Formula Junior
    May 15, 2012
    251
    Menifee, CA
    Jason T. DAmore
    #1 Jason T. DAmore, May 30, 2012
    Does anyone know how to remove the passenger side airbag dash cover. The leather is starting to deform the cover at the top corners (see picture) and i would like to remove it to have it redone. However, i was told that the cover is attached to the airbag unit. Can this be disconnected and removed? How??
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
  3. Jason T. DAmore
    May 15, 2012
    251
    Menifee, CA
    Jason T. DAmore
    That's on a 550. Is the procedure the same? Do I need to disconnect the battery before unplugging the airbag??
  4. cleonard
    cleonard Karting
    Sep 17, 2009
    117
    Indianapolis, IN
    Colby
    #4 cleonard, Jun 1, 2012
  5. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,271
    Northern Virginia
    You had the Airbag removed and then covered it? Is that even legal? I needed to get paperwork to get an on/off switch installed.
    If you ever sell it or have an accident, there may be liability issues.
    Best,
    dsd
  6. fished43
    fished43 Rookie
    Aug 15, 2012
    18
    Dave
    Giving this thread a bump as my 456 passenger airbag cover looks exactly like Jason's photo. Interesting replies, but question raised in original post remains and is exactly where i am at. Seems like the cover might just pop out allowing for easy repair and replace. Guessing that it is not that simple, and would rather that the actual airbag not "pop out" as well ;)
    Thanks in advance for any assistance here.
  7. tazandjan
    39,169
    On the 575M, and I assume the 456/456M is the same, the airbag module is removed from the bottom by first removing the glove box. Make sure and remove the ignition key and disconnect the battery warns the WSM.
  8. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,164
    So. CA & NV
    Peter
    Looks very similar to changing the airbag cover on the 355 (same era so it makes sense). Several detailed step by step threads are available.
  9. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I recovered my 575 airbag cover by stretching the existing leather. I did not remove the cover from the airbag unit. It is removed from the car in one piece. I assume the 456 is similar.
