Passenger rear shock R&R | FerrariChat
Discussion in 'Technical Q&A' started by ckracing, Aug 5, 2013.
  1. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    Hey Guys,I need to R&R the passenger rear shock. If I place a support under the passenger rear suspension and remove the top and bottom shock bolts will the shock slide out. Or is there another way. This is for the passenger side only.
    Thanks in advance.
    Charles
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    For your 84 308, I believe you will need to remove a few other things near the top of the shock mount for access, and near the bottom of the shock mount also for access to swing things around.
    Technically, 2 bolts are all it takes but with these old cars, other things always get in the way.
  3. ckracing
    May 20, 2006
    728
    Charles
    Thank you
