Passenger Side Window Not Moving | FerrariChat
Discussion in '348/355' started by Rorie, Oct 19, 2010.
  1. Rorie
    Rorie Formula Junior
    Oct 2, 2007
    459
    Toronto, Canada
    Won't go up at all. Assume it has come off the rails.
    What's the best way to get at it? Taking off the inside door panel, or going at it from the outside panel?
    I can hear the motor working, it just will not move up, and it feels loose to the touch.
  2. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,633
    VA
    Brendan
    yeah it sounds like it either came off the tracks or the regulator arm has become separated. You will want to go in by removing the interior door panel.
  3. Rorie
    Oct 2, 2007
    459
    Toronto, Canada
    That's what I would expect, but when I looked at a few pics of people with the interior of the door off I was not sure.
    Good project to do tonight.
  4. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Here is a great step by step thread on removing the door panels:
    http://www.ferrarichat.com/forum/showthread.php?t=191977
    One note, I had a very difficult time putting the opening handle back on the door. It has to line up perfectly and it is a pressure fit. I solved the problem by taking the bolt that attaches the handle down to the hardware store and buying the same bolt, just about a half inch longer. I used the new bolt to get the pressure fit started. Then switched back to the original bolt to finish the job.
    Tom
  5. Rorie
    Oct 2, 2007
    459
    Toronto, Canada
    Thanks for that tip. I am sure that will save me some frustration!
