Passing lights - Fog Lights issue | FerrariChat
Discussion in '348/355' started by LetsJet, Nov 4, 2010.
  1. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    The passing lights work when you pull the stalk back on the steering column.
    The fog lights (passing lights) don't work when I flip the switch on the center console - though the indication light goes on on the upper left dash as though they are on.
    I was told the fog light relay might be bad but I don't have the schematics. If the passing lights go through this relay then it seems the relay is working.
    Thoughts? Anyone have the wiring diag.?
  2. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    The relay for the fogs is in the passenger footwell fusepanel. Ferrari uses the same relay for a few of their electrics on the 355. Just swap one with the fogs and see if thats the problem.
  3. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Unless I'm reading it wrong, according to the manual the relay is in the bonnet and a little difficult to reach. I can do the swap but I thought I'd check here first.
  4. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    No one has the wiring diagram?
