PC problem ... "improper CPU speed" | FerrariChat
Discussion in 'Technology' started by Z0RR0, Jan 17, 2006.
  1. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    PC is a desktop, P4 3GHz, 16 months old or so. We ahd plenty of problems before (motherboard, CPU fan, sound ...), but now here's a new error.
    When just using Windows, the screen goes dark (puter still on). So I reset the computer with the good old button, and on start up, it goes in the BIOS and tells me something about last startup having an improper CPU speed and that I should set it back to what the hardware says. So from there I select 3000GhZ (my only choice other than "Manual"), but it will bug again later in the day or the day after ... this time I made sure to set all the Bios crap on Default .... we shall see.
    Thing is, I never (obviously) played with CPU speed ... just typical windows stuff, internet, music, Pshop ... etc
    Don't tell me the motherboard is going (again) or the CPU ... that would be annoying.
    BTW - haven't found anything relevant via Google, talks about voltage fluctuations, CMOS, jumpers ... just about everythign appears to be the culprit, and I don't understand a damn word!!!
  2. WARDHOG
    WARDHOG Formula Junior
    Feb 12, 2004
    491
    Bubbaland, USA
    Disgruntled Dave
    Is your computer showing the correct time or do you have or have set your clock?
  3. Mario Gonzalez
    Mario Gonzalez Formula 3
    Apr 13, 2004
    1,333
    Out of my mind
    SAVE ALL OF YOUR IMPORTANT FILES TO DISK NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  4. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    Clock gives the correct time ...
    And all files have been saved indeed! :)
  5. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    Did you update your powersupply?
  6. ralessi
    ralessi Formula 3
    May 26, 2002
    1,093
    Houston, TX
    Rikk
  7. racerx3317
    racerx3317 F1 Veteran
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    It sounds like the CPU and motherboard are mismatched in speed, are you sure the right one was used when it was replaced? Glad all your files are saved, that's a crash waiting to happen
  8. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    Well, it was quite a while ago since they changed the motherboard, several months, but the problem only arose recently ...
    matteo ... powersupply? are you talking about the box where the 110V goes in and mistery electricity comes out? How do you update that???
    the issue with hardforums is that they talk in bits and I understand ... well ... bits (bad pun, I know)
  9. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    Yes. You can replace them for like $10. Get one that is rated higher then what you have.
  10. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    matteo is correct in that an inadequate and/or faulty powersupply can cause random and inexplicable errors.
    But before you try swapping that out I would jot down your current BIOS settings and then powerdown and pull the CMOS battery for a few minutes then put it back in and reset the BIOS to the settings you had prior to pulling the batt.
  11. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    $10 ??? you buy a 10 buck supply and you're asking for more problems than you have now :D
    Get a good brandname supply like an Enermax or many others with atleast an output of 350-400 watts minimum.
  12. Etcetera
    Etcetera Two Time F1 World Champ
    23,988
    C6H14O5
    What brand is the PC?
    My first thought is the BIOS is fubar. Try reflashing the BIOS before you look elsewhere.
    You need to know what system it is and/or what what mainboard is in it prior to flashing.
  13. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    The guy doesn't know what a PSU is, I wouldn't suggest reflashing the BIOS! :)
    Can you get a digital camera and take some pictures of the BIOS settings?
    The PSU could be the issue, but it could be a hundred other things. Can you give me full specs on the system?
  14. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    It's been awhile :) That's how much they were back in the day. Hell, I don't even know how much bread or milk costs :)
  15. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    You're older than I thought.. a decent PS is at least $80~ now.
  16. Etcetera
    23,988
    C6H14O5
    Problematics, the Center for the Study Thereof, Moscow
    It, the PC, havet not enough juiceki to am blingen ag nok motherboard am dinglien. Yeltsin Blav Torovnaka unitsky der volta kabla dorfnas, unter um der 1.5 volta bringen mit.
    Putski all that new, and it makechevski like booten gevundern kaplinski.
  17. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    SWEET JESUS!!
    You up late or early? I'm in NYC so that is my excuse.
  18. Etcetera
    23,988
    C6H14O5
    I thought you were due for gender reassignment in the latter half of February.
    How good are the magazines in De Clinque de Venusio?
  19. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    stop hanging out with WAX
  20. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    The problem "changed"!!!
    Now, Windows will only start in Safe Mode ... in normal mode, it will just turn into a black screen ... and nothing will happen. Doesn't sound like a power supply issue any more, to me at least...
    As for the specs , the MB is an Asus P4S800-MX (it's an HP exclusive board ... for some reason, the PC isn't an HP, assembled by some canuck manufacturer called Axess), processor is a P4 3GHz, one stick of 512Mb RAM. Power supply is an HEC-300AR-TF (300W) that specifies Pentium 4 ready ... plus the array of graphics board (NVidia something), 160Gb HD, DVD burner and CD.
    However, as I opened it to look for the name of the MB ... the damn thing is filled with dust!!! 2 months ago, it was getting opened (and clean), and now it is cluttered with dust. Sooooo, I may have found my problem. Yeah, the CPU radiator is clogged with dust, the intake grill is as well ... I do feel like a dumbass (although I never thought it would get that dirty that quickly!!!).
    So, considering the new problem about Windows not starting up, and apparently all caused by lack of cooling ... have I fried anything? Or am I good just cleaning it up? Is it still the PSU?
    Yeah, I really do feel like a total dumbass ...
    edit - I cleaned it (bring out the air compressor, biatch!), Windows still wouldn't work, did a system restore, it restarted on its own correctly, but there's still a huge gap when Windows starts ... first windows logo, then a black screen and no activity for what feels like an etenity (20-30 seconds, perhaps) ... adn then carries on like nothing happened. It's a minor issue, now.
