Perfect Fit | FerrariChat
Perfect Fit
Discussion in '348/355' started by Roth, Mar 2, 2017.
  1. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    #1 Roth, Mar 2, 2017
    My opinion has always been the 355 spyder is the most beautiful car today. The interior fit and finish however fail to match its exterior curve appeal. What I dislike the most is the steering wheel. So I like to add a little more life to the inside and having searched the Internet, I found one that is pleasing to the eyes; the 550 bachata Maranello steering wheel. It appears to be an exact fit. Any of you gentlemen familiar with this, know of or have experience to prove my assessment is correct?
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    I dont think its a direct fit.
    I know for sure the 360 is and I boight a crappy 360 wheel and set it to glen and he fixed it.
    I will post a pic
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    #3 taz355, Mar 3, 2017
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    Vary similar to the one you have pictured also in carbon fibre.
    Cost of the wheel plus I think about 800
  5. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #5 275GTB, Mar 3, 2017
    remeber you have to buy the airbag as well, they are not cheap!
    I fitted a 360 wheel and airbag to my 355, 15 minute job, straight swap and the wires for the air bag are the same as the old 355 wires, just remember to turn off the battery via the cut-off switch, when doing the swap.
    it one off the best changes i have made to the car, the 360 wheel feels great.
  6. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,341
    Southern New Jersey Shore
    Phil
    #6 PhilB, Mar 3, 2017
  7. buddyg
    buddyg F1 Veteran
    6,372
    Naples, FL
    Buddy
    Wow those are not cheap!
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1 .......at $3150.00 (but there is a $800.00 core charge)
    https://macarbon.com/
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    You dont need to buy the airbag but I did. Someone on here installed one without and built a cover that looks factory.
    Do a search
    They did a pretty nice job as I recall.
  10. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    PhilB, the price is a little steep. I plan on keeping the original wheel.
    Taz that's a fair deal. Does he have one without the rib on the side and with a yellow ring?
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    Its totally customizable. Talk with glenn and tell him I sent you.
    Hes very good at what they do. Lots of other stuff as well.
    If I recall I saved a few hundred because he had it in stock and used mine to build someone elses.
    Thats whats nice you can usually pick up a used or burnt 360 wheel that will still work and has damage way cheaper.
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
  13. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    Thanks Tazz. Fairly priced. The airbag might not be
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    No airbag but Imsaw one on ebay for about 500 bucks
