performance cam regrinding | Page 7 | FerrariChat
Discussion in 'Technical Q&A' started by snj5, Dec 6, 2003.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,855
    The twilight zone
    I meant filter assembly, which would include the box...I should have been more clear.
  2. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #152 snj5, Aug 30, 2005
    Talked to James today about the runs; he feels that the larger venturis will help, and a different type of air delivery/filtration system is key. While the SAE numbers are in theory corrected, he did feel that the fact that the dyno room was 110F definitely made a difference, and that a run in February would be a different kettle of fish.
    Chris Fricke on the other board relates: "I found some old Weber chart, it sees the diameter of the main venturi for a 400cc cylinder with a HP peak at 7000 rpm in the 38mm range. For 8000 it states 41mm ! So your 36mm ones are sure worth a try." This is a bit different than Pierce told me, stating that 34mm venturis were good up to 320 hp in my application.
    It will take about an hour to change out the venturis to 36mm, the largest available for the 40DCNF and the same specification used on the 308 LM car producing 300+ hp on P-6 cams, albeit at higher rpm and compression. If the new cams can generate enough air velocity through the 36s to keep good street throttle response, then they stay in.
    If anybody has a burned-out airbox that I can salvage the snorkel, I'll look at welding it up to the port side for a dual cool air feed airbox similar to the Michelloto competition 308 box shown below.
    Many thanks
  3. edwardteach
    edwardteach Rookie
    Oct 22, 2005
    2
    Bath Creek N.C.
    What ever happened to the Elgin cams?
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    They took my cams, never delivered as promised multiple times, never wrote, never responded when emailed. Nothing. they still have my two intake cam cores - my bet is they are ruined.
    I am going to have to up the ante to settle unfortunately as Dema Elgin has treated me like crap and took advantage of the fact that I was deployed to Iraq.
    My experience. You be the judge.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,855
    The twilight zone
    2 things I meant to post months ago. When I dyno'd my car the last time, I spend a couple hours tuning, then made a pull, 360hp. Let the car cool for an hour and it made 420hp. That was a 95 degree day, I'm pretty sure a re-do on a cool day would add another 30hp+, so I'm agreeing completely with James.
    Second, old race bike was an 860cc twin, 430 per cylinder, redline at 9000, hp peak at 8200-8400, torque peak at 6500, so similar to your engine. Going from a 38 to a 40mm venturi added about 12hp (x4 for you). If I could have found a bigger carb, I'm sure a 42 would have been good for another 5+hp and 44 another 1 or 2 on top of that.
    Now these were slide type carb, so increasing the venturi doesn't hurt the bottom end anywhere near as bad as on a butterfly carb, but it goes to your point about bigger is better.
    That's is and always has been the fundimental problem with carbs, at the limits, they fail....what I mean is that your car runs great now and you love it, but you know going bigger will make more hp, but you also know it will harm the bottom end and drivablility. Going big enough to get the last couple hp will make it completely undrivable on the street. The general practice is to keep going bigger until you can't live with the result down low, then go back down 1 size to the one you could live with.
    One possible solution (and I know it boarders on blasphamy) is to see if you can find a slide type carb. Yamaha used to put 38mm flat-slide down-draft carbs on there YZR1000. I fitted 6 of the to a 2.8 liter 911 that made over 360 hp. They can be had for about $100 for a bank of 4. A honda super hawk has a 48mm flatslide, but I'm not sure if it is a downdraft, or more like a 45 degree, I think it's a downdraft.
    The last option is to just joy the cool toy you built!
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Mark - many thanks as always.
    I did back down to 34mm venturi as the 36 gave a bit of a hole in transition that annoyingly occured at cruise speeds, not uncommon. Based on the hp/torque charts, I do agree that she just runs out of air, probably at the head. Some of Kermit's QV head flowbench numbers back this up.I think I have cam, airflow and fuel delivery that are currently head airflow limited and still hold a lot of potential. I have always heard that one reason the 348 did so much better in specific output was they cleaned up the head porting from the 328. Would like to port the heads and try 34 and 36mm venturis, but would have to bring the main jet way up to bring the main circuit in earlier and then lean it with the A/C (210?) & et (F36?).
    On a side note, my little odd misfire sound down low was cured by backing off the advance and hotter plugs.
    So how much is head porting? :) Maybe next year or so as it is really sounding great now and runs sweetly. The Mondial to me is all about balance, and I have more than enough power to find the outside of my driving skills.
    Now, back to finish putting in a new Alpine stereo system, cleaning up the A/C and installing the new semi-auto antenna......
    best
    Russ
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,855
    The twilight zone
    So you found the tolerable limit of venturi size. Porting is goning to run about $2000 for a basic job plus install I'd guess. What about a set of 355 heads on that puppy?
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,855
    The twilight zone
    I was just thinking cams again and looking over this thread and noticed this:
    On the 348, the torque is almost dead flat from 4000 to 7500, it's really nice.
    On Russ's carbed 328, a stock 328, an EFI 328 and every other 328 and 308QV graph I've every seen, the torque starts to drop at 5000-5500 and keeps dropping until redline. The drop in torque is about linear with rpm, that suggests that something ability to flow is reached at 5000-5500.
    Anybody ever figure out what the hold up is? I thought is was probably the cams and the intake in particular, but the fact that changing the intake cam didn't help says it's not.
    Anybody know what is different about the 348? Cams? Cam timing? head CFM?
    The other thing that I've noticed on my supercharged engine is that I am pumping enough air and fuel into the engine to make about 800hp but only getting about 500, maybe 600 figuring it takes 100hp to turn the supercharger. The turbo QVs use about the same air/fuel as I do so it's something in the engine.
    I'm thinking there are 2 problems. The exhaust port flow is just too high and there is too much valve overlap causing cylinder blow-down and accounting for the high air/fuel usage. And there is something wrong with the flow of the intake port that causes the torque to drop. I think it's got to be the head because CIS, EFI, Carbs all show the same symptom....and it's got to be a port not a valve problem because the 328 uses a bigger valve than the QV and it doesn't help
    Any have any thoughts or data to share? I'm thinking my heads need to come off to correct it, but I'm not sure if the answer is to just buy a set of 348 or 355 heads and make then fit or some port/valve work will straighten out the QV heads. Anybody have a dyno curve for a QV/328 that's had the heads done by a professional?
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Mark -
    based on the nominal changes I had moving to a higher lift/ longer duration cam - it's the 3.2/qv head that is max flowed. This fits historically as the 348 head was re-designed and does flow better with practically identical cams I am told; this also fits with what I see.
    If I had to do it over again, I'd port the heads with the money I spent on the cams.
    Of course, If I do anything else that will be next. Except perhaps my eternal quest for a better airbox...
    russ
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,855
    The twilight zone
    You see, now I'm going to have to pull the heads off. :)
    My bubby with the head shop was out for New Years. He looked at the dyno graphs and cam specs and thought that I already had plenty of cam, and your results with cam change basically confirmed that.
    The funny thing is that when I rebuilt my engine I did it in his shop. We both looked at the heads (I had a flow bench before he did) and didn't see anything obviously wrong, in fact he had trouble believing they were factory....and we decided not to do anything to them since it was a blower motor anyway. So it will take some figuring to decide what they need. He's thinking the place to start is sinking the valve to extend the porting into the head, but that will drop the already low compression so I'll need pistons. If I need pistons anyway, I may go crazy and see if I can get 348 or better yet 355 heads on the engine. 355 heads should add about 200 hp.....that I don't need of course :)
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Heck, while you're at it, see if the 348 or 355 block will mate up with your sump case. Then you'll pick up displacement as well as the flow to go with it. ;)
    Sorry for the belated response, was doing a bit of catching up on some of the performance threads & saw your question. Anyway, here it is:
  12. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    All of my dynos have been dyno-jet, fixed facility.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,855
    The twilight zone
    I have a brand new thought tonight - reversion/resonator.
    I was playing with my dynosim soft ware again tonight….I don’t really like it because I have a terrible time getting the number to match measured values, so I don’t consider it validated. Anyway, I noticed something and that is that when I put on the factory QV/328 type manifold, I get a torque curve that is the correct same with peaks in about the right places, with the torque falling after about 5500. When I put on carbs, I get about the same shape curve with the torque falling after about 5500. So that’s right.
    But, when I put on a 348/355/360/456/550/575 type manifold, I get a torque curve that peaks in the same place, but then stays flat out to about 7000…it looks exactly like the 348 graph that’s posted.
    So I have a brand new plan. I am going to pop the rear head off and get some flow number so I know and based on that I may or may not port them. But the main part of the plan is I’m going to build a new intake manifold (actually a pair of manifolds) that are a lot more like the 348 set-up. There has to be a reason that every ferrari engine built since 1989 uses that design and I’m guessing it’s the same reason the dynosim software wants it.….plus it’s way less work than the 355 plan :)
    And Russ, I pretty sure adding the same kind of thing on top of your carbs should help your Carb engine too.
  14. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #164 snj5, Jan 3, 2006
    Mark - I think you are correct about reversion pulsing being optimized by having a separate 'plenum' for each bank. So, it kind of builds on the flat crank theory of seperate optimized exhaust headers for an 'independant balanced bank pulsing' may apply to the intake track - I think this is where you are going, no? There is also the advantage in the separate and smaller tracks of a relative increased air velocity rather than a large plenum.
    So for me - AND every other carb 308 - there may be some advantage to each bank having it's own separate airbox acting as this resonant chamber. It would basically look like the top of a V-8 Lamborghini Jalpa, except should consider placing a cone filter on a duct upstream of the 'airboxes'.
    Other advantages off the top of my head would be increased filtration area and a more open carburation area for cooling air flow (the stock single airbox holds heat around the carbs).
    Here's a picture of a Jalpa dual airbox system:
  15. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,585
    E ' ' '/ F
    Enzo Gorlomi
    #165 GrigioGuy, Jan 3, 2006
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Tillman - you just reminded me that the Lancia Thema 3.2, even though it had a 90 degree crank, also had dual plenums....
  17. GrigioGuy
    Nov 26, 2001
    33,585
    E ' ' '/ F
    Enzo Gorlomi
    Yep, with very long runners compared to the Ferrari version. Good luck finding one, though. I finally gave up.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,855
    The twilight zone
    #168 mk e, Jan 4, 2006
    That's pretty much exactly what I'm thinking....although I suspect there is probably a flow/tuning advantage to a tubular chamber over a sheetmetal box...in a thin wall box the walls will probably flex as pulses hit it, in the tube they won't, I don't know if it matters but ferrari seems to make them strong.
    Something like a pair of these:
  19. edwardteach
    edwardteach Rookie
    Oct 22, 2005
    2
    Bath Creek N.C.
    Still curious about what happened to them Elgin Cams? Any updates?
  20. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Elgin Cams kept the cams I sent to them without delivering as promised, provided no refund, does not answer email or phone inquires and is ignoring my pleas even to just return the cams he seemingly has ruined and took advantage of the fact that I was deployed to Iraq in the Air Force and could not easily press the issue.
    WEBCAM on the other hand, did a nice regrind without problems and delivered promptly with excellent customer service
    One of the important findings from the qv cam upgrade was that the 3.2 cams already max flowed the head, and to take advantage of increase in lift or duration, some headwork will be neccesary
    There is a head porting thread that is developing as I look at doing that next to take better advantage of the cams.
