News
Performance times - 360 vs Stradale
Discussion in '360/430' started by poyta, Mar 29, 2004.
  1. poyta
    poyta Karting
    Mar 7, 2004
    203
    Adelaide
    Peter W
    Anyone know the performance times of the 360 Modena compared to the Stradale?
  3. fatbillybob
    fatbillybob F1 World Champ
    Aug 10, 2002
    19,178
    socal
    I'd be curious to know the 100mph to zero stopping distances between the two. The disposable supplies for the stadale system are more than the cost of other people's new cars! I wonder if the $30k brake job can really stop you that much faster.
  4. Izza
    Izza Formula 3
    Nov 3, 2003
    1,046
    London
    Independent reviewers confirm the Stradale's deceleration is 15% greater than the 360. However, this is also dependent on the softer rubber. Manu and co in Egham are helping me fit Stradale wheels and tyres to my spider. I can then post the difference that the rubber makes.
    As for the difference the CCM makes - I'm still saving for a CS!!
  5. Victory
    Victory Formula Junior
    Jan 28, 2004
    410
    It's 2 sec faster than the 360 around Fiorano. It uses P Zero Corsa and it's not that much different from the P Zero tyres. It's the Michelin Pilot Sport Cup that's the stickier tyres. Wonder why Ferrari doesn't offer that.
    Two of my friends had theirs already and they're raving over the CS. And they were 360 owners, so I believe them.
  6. adlinyusman
    adlinyusman Rookie
    Feb 5, 2004
    23
    Malaysia
    Eddie
    but are they (performance difference) noticebly different in real world non track day usage?
  8. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Actually, this is TOTALLY dependent on the stickier rubber. Carbon brakes hold no advantage over iron with the same tires when testing just one stop (fade not an issue). The limiting factor is tire traction for any single stop. On the track where fade becomes an issue the carbon may have an advantage, if you can stomach the cost of replacement pads and rotors. There are a lot of Porsche GT2 and GT3 owners paying to swap out the ceramic brakes for iron.
    Gary
  9. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    True; though the bigger brakes can also benefit you in better modulation and control in threshold braking; and as you up the forces via better rubber, that becomes more important.
    True; but the Porsche PCCB's seem to be fairly defective for track use; in contrast, the Stradale brakes seem to be proving themselves so far. Let's hope they indeed live up to their billing... unlike the PCCBs.
  10. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    In this day of very effective anti-lock brakes, how important is this?
    I hope so, too. It does appear there are some significant differences between the PCCB system and the Ferrari carbons. Replacement costs are still gonna be high on the Stradale, though...have you priced pads?
    Gary
  11. Izza
    Izza Formula 3
    Nov 3, 2003
    1,046
    London
    Via discussions with Brembo UK they are looking to put a kit together than will replicate the caliper / disc size of the CS with a steel disc. These obviously require the larger wheels - once I have got these fitted with the larger, stickier rubber I will then look to the brake upgrade and revert.
  13. loungedog
    loungedog Formula Junior
    Nov 6, 2003
    286
    New Market, Ontario
    What about the benefits of the weight savings of the carbon fibre brakes regarding ride quaility and handeling??
  14. stradman
    stradman Formula 3
    1,272
    London UK
    Stradman
    Ferrari actually say it's 3.5 secs faster around Fiorano.
  15. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    7,070
    Until ABS kicks in and destroys your feel for the threshold.
    In threshold braking you are trying to hold the tires at 7% slip* with respect ot the road surface passing under the contact patch (Miliken and Miliken "Race car vehicle dynamics"). This is past the point that ABS want/needs to intervene to save your butt if you are not trying to threshold brake.
    *point of maximum traction in the decelerational sense.
  16. Izza
    Izza Formula 3
    Nov 3, 2003
    1,046
    London
    Through personal usage I agree fully.
    I have attached CS wheels and tyres - the lower profile/stickier rubber gives a dicernable increase in "bite" even when using on the road.
    Increased brake discs and calipers to go but the improvement already has made the process worth it anyway!
  17. Brian C. Stradale
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Actually, besides the stickier tires, there is also the increased downforce to consider. Won't matter when braking from 50-0; but from 100-50, the added downforce will definitely improving braking effectiveness... and on the track 130-100 will have even more effect from downforce. Its amazing the size of that wing they managed to stick under the rear of the Stradale!
    As for the CCMs effect, another effect, not mentioned above, comes into play on real-life roads (more so than the track)... their light weight substantially reduces the unsprung weight, which means over bumpy surfaces the tires will tend to stay in contact with the road better. And that of course will greatly improve stopping distances when stopping on a bumpy surface.
