Permanent power point in rear trunk? | FerrariChat
Discussion in '308/328' started by Zenobie, Oct 2, 2024.
  1. Zenobie
    Zenobie Formula Junior
    Feb 22, 2021
    251
    Belgium
    CO
    The Ori antenna is broken and I am installing a new automatic antenna, but the new one does not work via Ferrari dashswitch. Should work via continuous power and via radio control wire. Is there a continuous power supply somewhere at the back? Anyway on the ori antenna wires there is no continu power so?
  2. Steve Magnusson
    26,785
    By "continuous power supply", do you mean:
    +12V with the key "on"
    or
    +12V always (even with key "off")?
    Zenobie likes this.
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    #3 mike996, Oct 2, 2024
    I'm not the original question asker but I'm looking for a KEY ON 12V source back there to connect a backup camera. There has to be one on one of the Microplex terminals but I wonder about connecting anything else to that point for fear of affecting Microplex operation.
  4. Steve Magnusson
    26,785
    Yes, probably not great to use the +12V going to the Microplex ignition ECU. How much current do you need? If you have a US version 328, IIRC, some of the air injection system stuff on the engine has +12V key "on" going to it, but anything more than about 1A would be getting OB.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Thanks Steve - Yes, a US 1989 328. I don't know the camera power consumption - and I'm not where the car/camera is located until late November but I would think the draw would be a watt or two at most so well under an amp. But I admit I'm guessing re the power draw... ;)
  6. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    Hi Steve, Actually key "off" as when I drive there is enough nice engine sound :) and I only listen to the radio when standing still and engine off.
    Mine is a E version 1986 328
  7. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    Mike- bc you will be using it for a back up camera can you wire it to your back up lights or does the camera need power at all times driving or parked
  8. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,148
    SanFrancisco BayArea
    1983 US 308 GTS QV
    There already is an unswitched 12v power source at the antenna.
    The switched 12v sent to the antenna is only a signal voltage. When the ignition switch is in 'run" position and the antenna switch is "on", a 12v signal is sent to the antenna system to tell it to raise the antenna using the unswitched 12v source.
    When the engine is turned off or the antenna switch is flipped to the "off" position (and the signal voltage thus drops to 0V), the antenna uses the unswitched 12v source to run the antenna motor to lower the antenna.
    Zenobie likes this.
  9. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    Ok, but by using the normal connection and the switch of the Ori antenna I already destroyed 2 antennas. This is an antenna type as discriped in other threads were if you want to use it you have to do something with a diode or so but to do so i ame not competend :)
