Pertronix set up on a vintage Sun machine | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by P400, May 7, 2007.
  1. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    Recommendations on a previous product of theirs. I dug around a bit and then picked up the phone and called them. They are quite knowledgeable.
  2. staatsof
    96,371
    Fuggetaboutitland
    Bob
    With respect to all the NLA Marelli stuff you mentioned, it sounds like they should start making the stuff again or release the technical specs so that anyone can have this done. There are a lot of these distrributors out there.
    I wonder how many of these cars run like sh*t because it's just too big a
    pain to deal with the fix?
    Bob S.
  3. staatsof
    96,371
    Fuggetaboutitland
    Bob
    If the price of the two tubes of smallest size lube makes one pucker then the
    price of everything else on these cars will positively make you turn inside out!
  4. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    I should probably rephrase the term NLA… in reality the majority of this stuff was *never* available. Marelli didn’t make spares then and they’re not going to now. Things like bearings and breakers and the occasional o ring are relatively easy to come up with. The advance mechanism kits that Superformance carried(s) were a great idea but horribly executed. (Again, that may very well have changed by now… they’re not known for things like this. I buy quite a bit of stuff from them and am very happy 99.9% of the time.) It would be nice if the weights GT appears to have were well made. That would help tremendously.
    In terms of technical specs, they’re all right there in front of us. Reverse engineering these things out to full blown drawings can be done in a matter of a few days. Resolving the original design flaws wouldn’t take much more. In short, they are very nice distributors that need a little help to be brought forward to today’s standards. I’m well on track towards resolving the majority of these items and plan to refine them on my own cars. If you’re going to bother making parts like this it’s just as easy to make 100 as it is 10. That said, sooner or later there will be parts available again.
    Yes, I think the majority of the early cars that run these could use a bit of help. It’s not a pain to deal with the fix. It’s easy. The problem is you need someone that is familiar with Marelli’s and has a well tuned distributor machine. Then you have to be willing to *pay* that person for their knowledge and time spent. That’s the pain. I put a *silly* amount of time into each distributor I do. But I don’t know any other way to do it and am not willing to compromise the basic sense of craftsmanship that I apply to most everything I do. Folks with the 127’s have it much easier than those trying to get a pair of 159’s working properly. Points or Pertronix, it doesn’t really matter. This is why so many people move to more modern components such as crank triggers. By the time you’ve got a pair of 159’s in shape and back in the car you’ve likely spent the cost of an entire Electramotive setup. And you’re gonna have to spend that same money, if not more, the next time around. I can’t blame anyone for scrapping the stock stuff. Like I said earlier though, I just like my engine compartments to appear generally stock. Emphasis there on generally… :)
    This is exactly why ideas like BirdMan’s repository are such a great thing for the community. Had you guys been able to just pop over to his site and find all this info in a nice and tidy pdf you probably would have been good ages ago. As much as we all like working on these things, it’s so much nicer to go flog them.
  5. staatsof
    96,371
    Fuggetaboutitland
    Bob
    I think I remember what that's like.
  6. staatsof
    96,371
    Fuggetaboutitland
    Bob
    Ok Rob, you've mentioned it twice now, who is the "birdman" and where is this site?
    I think a lot of owners have simply let the dizzy go. That screwball pair of distributors with the 5 degree retard at idle design for the 308 certainly doesn't boost the desire for keeping the original stuff either. I have a friend that just went the Electromotive route on a QV. Not everyone is into original or even quasi original like us.
    Bob S.
  7. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    690 posts and you don't know who the BirdMan is? What rock did you just climb out from under? :) :)
    Seek enlightenment here:
    http://www.ferrarichat.com/forum/showthread.php?t=150316
    You know, with all this yapping about these Marelli's I'm real tempted to go score one of the Electramotive rigs just to see what they're like. Probably a really bad idea though... :)
  8. staatsof
    96,371
    Fuggetaboutitland
    Bob
    I know of four guys that have put them on.
    Paul with a 308 QV injection & ignition for his track car. He's on this forum.
    Steve, a.k.a. Fasterisbetter, also on this forum has recently put the ignition system on.
    Then there's a guy on a Lambo forum who's done the injection & ignition system on his Espada. He's also got nitrous.
    Another Espada owner has just the ignition system.
    A number of people have done the ignition system on Countachs.
    It's not Motec level stuff but it seems to work ok for these guys.
    For my Espada the cost is about the price of a cap rotor and points if I were to buy the original equipment. I did not. I'm using Jag bits. But .... there is the work of fitting the sensor wheel and securely mounting the crank sensor.
    On my engine this is not so easy unless you want to remove that sensor every time you change an AC or alternator pump. What I'm doing appears to be a lot easier (????) in some ways and harder in others. The performance results won't be as dramatic though. Hey, it's a vintage car not a 599. It will look very stock and not have a trigger wheel, six coil packs and a controller box on display in a late 60's engine compartment.
    Bob S.
  9. P400
    P400 Formula Junior
    535
    east coast
    Craig
    Hi Rob, sorry i have not been back at this topic, senior moment.
    i bought my laser tach from Ebay buy it now similar to -
    #220114632700
    i cannot remember the vendor, but i was unhappy with the payment routine, it required you to fill out some online forms which i thought was unecessary.
    total cost was about $32 with shipping. you can use this laser tach to check lathe , drill press and other shop equipment.
    thanks for your help on this Pertronix issue.
    Craig
    Where did you score your laser tach? I’ve been wondering about the accuracy of the meter on my 504 and went so far as to temporarily rig up one of those big tachs you see all the kids put in their Civics. Didn’t work too well as it only had the option for a two pulse four cylinder…Rob
  10. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    Thanks!
    Exactly what I was thinking of.
  11. staatsof
    96,371
    Fuggetaboutitland
    Bob
    Rob,
    Now that I'm in the final assembly stage (sensors are mounted nicely) I have a couple of questions I'd like to run by you.
    Bob S.
  12. P400
    P400 Formula Junior
    535
    east coast
    Craig
    Bob, do you have any pics of your latest Pertronix installation version?
  13. Beta Scorpion
    Beta Scorpion Formula 3
    Jun 22, 2006
    1,379
    I will say I am using Optical, rather than Petronix, (and I have a lot of adjustment available in the position of the sensor) but the alignment should be the same. Mine wound up with the distributors about in the middle of the distributor base adjustment slots. This is of some consequence, because the rotor has to align with the pin on the underside of the distributor at the time of spark, and this relationship changes as the timing advances. I have mine setup so that the rotor is just a little PAST perfect alignment to the pin under the rotor. Then as the timing advances, the rotor and pin line up perfectly. Two ways to check this alignment 1) cut a hole in a distributor cap and shine a timing light in there, or 2) use some putty to make an impression of the rotor on the underside of the cap.
    http://www.ferrarichat.com/forum/showpost.php?p=136339632&postcount=279
  14. staatsof
    96,371
    Fuggetaboutitland
    Bob
    The the distributors in question are off a Lamborghini and we have 42 teeth on the engagement gear to the cam drive so a lot of adjustment is available. In my case one tooth represents about 60% of the adjustment slot. This combined with a slotted mount should work fine. I'm also using a rotor with an extra wide contact area, over twice as wide as the original but I did align it about the same way as you based upon the original width of the contact so there's no way I can miss.
    I'm looking forward to seeing the engine/car run again. It's been 7 months.
    Bob S.
  15. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    You'll be fine. Get that thing to Craig and in the machine already! :)
    Thanks for the pics. I'm swamped right now but will get an email back to you in the morning.
    R
  16. P400
    P400 Formula Junior
    535
    east coast
    Craig
    Hey Rob and Bob,
    The Sun machine worked perfect! 9 volt little battery for power, the strobe triggers like rock steady points. i found the dual Pertronix were 1.5 degrees out from desired 30 degree spread, and Bob had provided adjustment slots, so adjustment only took a couple minutes. One Pertronix fires 6 cylinders, the other, 30 degrees out, fires the other 6 cylinders. Nice design and work from Bob.
    One Pertronix does indicate +- 0.5 degrees out on 2 out of 6 triggers, the other Pertronix i cannot find the same, seems perfect, cant explain why, not worried about it.
    Bob worked the weights and springs over and the Marelli S129C now advances more closely to factory specs.
    But to all who have followed this - My MDT50 Sun machine works fine with Pertronix. thanks for all the support, ideas, technical help.
    Craig
