Philip screws in 308 instrument panel | FerrariChat
Discussion in 'Technical Q&A' started by bonneaud, Feb 14, 2007.
  1. bonneaud
    bonneaud Karting
    May 3, 2004
    84
    The 4 warning light covers are out without any dammage (I used a credit card, cut it in 1 cm. strip after filing the end so that it would slide under the target and then used the dental floss trick and keep turning around the light cover unyil it pops). The 4 Philips srews are visible . There are 2 small ones at the top and 2 larger ones at the bottom , with a lot of wiring and a 5 cm, gap between the panel and the screw heads. What would be a safe way not to drop these precious scews behind the panel during reassembly? A magnetised driver doesn't seem strong enough given the "forest" of wires in my way...Suggestions? Thanks.
  2. Gerry328
    Gerry328 Formula 3
    2,441
    Home
    Gerry
    I have remove mine many times using a magnetized screw driver without a problem. I bought a magnetizer/demagnetizer tool through eBay for about $6.00 and it worked fine.
  3. bonneaud
    bonneaud Karting
    May 3, 2004
    84
    Good to know! I'll give it a try but it's a tricky angle for the top screws, do you go at it by feel only with the driver? Thanks again.
  4. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    Use a small piece of tape to tape the screw to the screwdriver, sounds crude but it works in a pinch.
  5. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,138
    E ' ' '/ F
    Snike Fingersmith
    The magnet screwdriver was 75% successful on my recent panel removal. Guess what I'm searching for right now? :D
  6. f355spider
    f355spider F1 World Champ
    18,045
    Use the magnetizer trick, that is what I did. It is not that big a deal if you drop the Philips screw...yeah, you need to take stuff apart, and all, but not that time consuming. I did the bulb upgrade on my previous 308 and 328, and only dropped a screw one time.
    Get to it! Are you telling me you have not put this back together, as you are search for the perfect solution to reinstalling the damn screws????
  7. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Lil bit of super glue on the phillips head driver, when screw is tight, lean driver to side to break glue grip. (Did I mention just a LIL-BIT of super glue.)
  8. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    There are products called Blutac, Silly Puddy can also work in a jam. A magnetic crewdriver works most of the time, but i find if i use Blutac/silly puddy or the like on the head of the screw AND magnetized driver it works about 99% of the time to keep the screw on the driver.
  9. docweed
    docweed Formula Junior
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    Next time you're at the dentist or if you are near a dental lab ask for a couple lengths of red rope wax...they shouldn't charge anything. It is a thick wax that is easy to manipulate and will hold screws to any tool and is good for retrieving a dropped screw.
  10. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    ... or just go out and buy a couple of extra screws...
    Hans
  11. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,954
    The Cold North
    Tom
    Silly putty works very well ( and you can play with it after!!) butal on the end of the driver works good, electrical tape..magnetic screw driver etc...
  12. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Dang...I'd quit going to a dentist who drops screws down your throat !!
  13. jdd308
    jdd308 Rookie
    Jul 25, 2004
    18
    John Dickins
    That credit card tip is excellent, bonneaud! I have been wanting to remove the instrument cowl for ages to recover it with a non-reflective material like alcantara [all owners will know why!] and now I can get started.
    The chap who looks after my car told me most of how to do this and he did recommend not using magnetised drivers as they risk upsetting the instruments. Don't ask me how, I imagine there are delicate parts in the speedo & rev counter.
  14. GrigioGuy
    Nov 26, 2001
    33,138
    E ' ' '/ F
    Snike Fingersmith
    Hmmmm. I didn't realize that these gauges were precision instruments -- I've always found them to be, at best, approximations of reality :D
    Thanks for joining us in our chatter :)
  15. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Isn't the proper pronunciation of "Vaglia" - "vague liar"???
    with malice aforethought,
    cm
    Ps, the magnetic driver works well getting it out and tape is better for keeping it on the driver to get it started, imho.
  16. docweed
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    I would think they would have to come out otherwise they rust.
