Photoshop help - Save for Web Problem... | FerrariChat
Discussion in 'Other Off Topic Forum' started by SefacHotRodder, Feb 22, 2005.
  1. SefacHotRodder
    SefacHotRodder F1 World Champ
    Dec 20, 2003
    11,158
    NJ
    Chris
    #1 SefacHotRodder, Feb 22, 2005
  2. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
  3. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    I knew you would help, thanks a lot
  4. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Randy, that didn't fix it.
  5. Schatten
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    are you sure you aren't working in CMYK and trying to save via web?
  6. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
  7. djoex
    djoex Karting
    Dec 7, 2003
    139
    Miami, Fl
    Joe Yeung
    would you mind sending me the project to see if get the same error, if i do theres a work around editing the registry... if dont then probably the file is corrupt.
    [email protected]
  8. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    I get it when i try to save any picture that way
  9. djoex
    djoex Karting
    Dec 7, 2003
    139
    Miami, Fl
    Joe Yeung
    ok then.. it in some other forums they have some solutions which i believe are the ones you've tried so far.. changing from CMYK to RGB etc.. the last resort is to edit the registry.
    check here
    http://forums.pcworld.co.nz/archive/index.php/t-40883.html
    post #2, before doing that i suggest to back up the registry and then do it.
  10. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Thanks man, i'll try that asap
  11. SefacHotRodder
    Dec 20, 2003
    11,158
    NJ
    Chris
    Awesome. I deleted the key and it works now. Thanks a lot.l
