Physical Key For Newer Ferrari: 458 Keys Be Recoded For 488? | FerrariChat
Discussion in '458 Italia/488/F8' started by Golden Steed, Jan 18, 2022.
  1. Golden Steed
    Golden Steed Formula Junior
    Apr 11, 2018
    772
    Golden Steed
    Ferrari no longer offers a physical key. Which is too bad, because the 458/599 era keys with built-in FOB were very cool.
    Has the encryption/tech advanced to the point that a blank 458 key can't be coded to a 488?
    Physical keys are cool. Robot car style key-less FOBs are not. There's a tactile sensation to having a car key that I feel like people really miss.
    Anyone have any idea if the newer cars can be hear the old key's signal?
  2. Golden Steed
    Apr 11, 2018
    772
    Golden Steed
    The tactile sensation of this....
    Seems better than this...
  3. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,574
    Menlo Park, CA
    Paul Chua
    I prefer the fobs. Just me.
  4. 458knows
    458knows Rookie
    Feb 11, 2023
    28
    Porter Ranch, CA
    Sk
    Same,
    could one hypothetically
    Program a 488 fob to a 458 and then cut the blank to start the 458?
    thus a 488 fob that controls and starts a 458
    paulchua likes this.
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,574
    Menlo Park, CA
    Paul Chua
    Anything is possible! Just takes time and money. :)
  6. 458knows
    458knows Rookie
    Feb 11, 2023
    28
    Porter Ranch, CA
    Sk
    Would be strange to pull out a key with no real end on it to start the car
  7. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,574
    Menlo Park, CA
    Paul Chua
    So the way the key works is there is a programmable cell within the key itself , it looks like a small glass pill. Any number of specialized outfits can program that pill and then you insert it in the innards of the 488 fob. Now in terms if the stock pullout key in the 488 fob is compatible with the 458, I do not know.
  8. SD455TA
    SD455TA Formula Junior
    A real key is THE only way to go!
  9. 458knows
    458knows Rookie
    Feb 11, 2023
    28
    Porter Ranch, CA
    Sk
    you’d need a blank that could be cut I suppose. Hmm I’ll be the poser with the 488 fob for the 458. I just really like key fobs
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,574
    Menlo Park, CA
    Paul Chua
    I don't think you are a poseur at all, especially for just having a key fob you really like. I'm sure you can find a specialized locksmith to cut it correctly.
    So the steps are.
    1) move the cell into an 488 key
    2) find a key expert to cut the key
    Doesn't seem that hard, though the devil are in the details - so I don't blame me if this goes south! I did reprogram a 612 and 456 key just as I described if that's worth anything.
  11. 458knows
    458knows Rookie
    Feb 11, 2023
    28
    Porter Ranch, CA
    Sk
    Ohhhhh move the cell….
    So it isn’t possible it make the fob a secondary key, you basically have to give up the original key? At least the electronics part??
  12. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,574
    Menlo Park, CA
    Paul Chua
    You should be able to buy a new cell and have it programmed so you don’t have to remove from your old key. Carefully add it into the 488 fob (if even possible)
  13. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,024
    PA
    Kevin
    Not entirely true. You can make a backup key that will start the 458 as long as you have the right blade (SIP22) that is cut to match your OEM key and a Smartchip that is cloned to your OEM key. A good auto locksmith can do this. I know because I did it.
    458knows and paulchua like this.
  14. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,574
    Menlo Park, CA
    Paul Chua
    Exactly,
    @458knows here is the cell that needs to be programmed, not sure if it fits inside the 488 fob though. Make sure you confirm that the 'pill' fits in the areas I pointed with yellow arrows as suggested zones.
  15. 458knows
    458knows Rookie
    Feb 11, 2023
    28
    Porter Ranch, CA
    Sk
    awesome might try this out as there is only one physical key so might make the secondary a 488 style fob. Thank you
    Challenge and paulchua like this.
  16. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,302
    Midwest
    Ivan Drago
    Any updates on this experiment?
