Physics Majors Please Respond | Page 2 | FerrariChat
Discussion in 'Other Off Topic Forum' started by venusone, Jul 14, 2005.
  1. LZeitgeist
    LZeitgeist Karting
    Mar 23, 2005
    190
    Raleigh, NC - USA
    Patrick
    I suppose I stand corrected by your experience, then... my experience is that air tools do much better at removing sensitive items like rusty exhaust manifold bolts, whereas wrenching on them seems to break them off more often than not if problems are encountered.
    I will say that I would never advise using air tools to *install* bolts/nuts (as you say, there's a much better 'feel' to using hand tools), but I've always had better luck with air as far as removal goes.
    Perhaps other forces are at work that I did not take into account. Apologies if I gave ill advice.
  2. Poweredbyme91
    Poweredbyme91 Formula Junior
    Dec 9, 2004
    942
    Now in San Antonio
    Hector Silva
    #27 Poweredbyme91, Jul 14, 2005
    I dont know if anyone has mentioned this but I used a car jack to take my stubborn lugs out of my Legend and it worked. Slide a hollow bar through the wrench or what not all while resting the bar on the top of the lifter and raising it up. Worked for me, Might work for you.
  3. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    Uh, about using the jack...be very careful trying stuff like that. In fact, don't. You can seriously hurt yourself with things slipping and flying off if you try and use them in ways they are not designed for.
  4. Artherd
    Artherd F1 Veteran
    Jun 19, 2002
    6,588
    Bay Area, CA
    Ben Cannon
    This is a really, really, really really bad idea!
    Get an Ingressol Rand impact wrench with ajustable torque. That will knock 'em loose.
  5. Poweredbyme91
    Dec 9, 2004
    942
    Now in San Antonio
    Hector Silva
    LOL. I guess I just got lucky. Got the work done but I didnt think it was that dangerous, I guess I do now.
  6. vraa
    vraa F1 Rookie
    4,606
    Texas
    Mr. A
    Some C4 with plastique. You can ask the guy that was refusing the American Flag stamps for some :)
  7. ^@#&
    ^@#& F1 World Champ
    12,091
    See the C4 would blow up the car and the surrounding neighborhood. That is why I suggested an M-80
  8. DGS
    DGS Seven Time F1 World Champ
    73,562
    MidTN
    DGS
    #33 DGS, Jul 15, 2005
  9. Steve R
    Steve R F1 Rookie
    3,018
    MeSoNeedy, CA
    TorQ Master
    Hmmm....I could have my mother-in-law come over and just nag at the nuts: they'll fall off in no time, seems that's what happened to my father-in-law!!!!!
    OH!!!!!!!!
  10. darth550
    Jul 14, 2003
    61,206
    In front of you
    BCHC
    That can't be good for you know what they say!
  11. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Are you sure that you are not looking at reverse threaded bolts (ie. on the left of the car)? ... my Alfa is like that and confused me once ... for a few seconds ;)
    BTW: I would not use those nuts again ... and I would be worried about the damage done to the studs and wheels.
    Some *****head must have used pneumatic cr@p tools on your car :( ... pneumatic tools were invented for the production line, not for quality work!@!. They should stay in the rubbish bin where they belong IMO. Real mechanics DON'T use them (and yes well aware that F1 tyre changers use them, but they are not being mechanics/technicians ... and the amount of effort that goes in to designing those nuts for air tools is massive, I believe).
    Pete
  12. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    RSpeed was the last to check everything on a 30K mile check up, at the same time they installed my JR supercharger & JR cat replacement (already had the JR resonator & muffler). Got to Sav Tire too late. I'll try to get there when the line is shorter for them to bust a nut or 2.
  13. ryalex
    Aug 6, 2003
    26,198
    Las Vegas, NV
    Ryan Alexander
    What's funny is that this is what you see when you scroll over the title of this thread when you're in the Other Off Topic menu.
  14. vraa
    vraa F1 Rookie
    4,606
    Texas
    Mr. A
    What is this 'neighborhood' you speak off? We don't have those in stinkin' Texas!
  15. JonBrent
    JonBrent Formula Junior
    Nov 10, 2003
    732
    Heaven on Earth
    JB
    Karen,
    On my krap old 330, most everything was corroded together.
    What worked for me for the most stuborn bits is a spraying 'PB Blaster' on the parts for a several days (yes patience IS required, there is a soak in time you cannot avoid), then heat with propane or hotter PET (yellow can available at Ace HW) to expand the surrounding metal, then putting a SIX point socket/wrench on the head and slowly increasing the torque.
    WD40 is _Water Displacement_ Formula 40! Anyone using it as a lubricant clearly doesn't have a clue of what it actually is. Sorry guys, nothing personal, but this stuff turns to glue as soon as you spray it. Great stuff for bored cylinders you don't want to get rusty - that's the proper application.
    Patience Karen, that's the key sometimes.
    HTH, JB
  16. ECTurboGSX
    ECTurboGSX Formula 3
    Dec 26, 2004
    1,074
    Bay Area, CA
    Eric
    What tools do you have? If you have an air compressor that generates decent CFMs at around 100 psi, an Ingersol Rand 2135Ti will generate 1000 lb ft of torque in reverse and MSRP is $260. If that isn't enough to get it off, then just sell the car;) Also, on any quality air impact wrench, there are multiple torque settings. I have also broken more studs using hand tools as compared to air tools. The constant twisting force tends to do more than the repeated impact from an impact wrench. Also, with the using a hammer on the back side to knock a stuck wheel off, make sure you thread a lug nut on a few turns, otherwise you could screw up the face of the wheel if it comes off quickly. If your wheels are that stuck, I would suggest planning on replacing the wheels studs and nuts anyways. If they are stuck now, they'll probably get stuck again later. Its a relatively cheap fix for something that is obviously a major PITA.
  17. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    Most people do know what the WD in WD40 stands for. And yes, it does work as a lubricant as well. Try not to be so condescending.
  18. JonBrent
    Nov 10, 2003
    732
    Heaven on Earth
    JB
    You know, I think that's the first post I've made which got someones hackles up. Sorry Mr TVR if it came across as harsh, it was a long week for me, but that has been my personal experience with it.
    Have a great weekend.
  19. DGS
    73,562
    MidTN
    DGS
    Even water can be a "lubricant". Graphite is an excellent lube for precision parts (like door locks) that have to tolerate a wide range of climatatic conditions.
    But the best way to soften up a rusty fastener is "penetrating oil": good ole 3-in-1. But it doesn't come in a spray can.
    Sometimes, you just have to get your hands dirty.
