Picked up my Dino 246 GT Chairs and Flares car today | FerrariChat
Discussion in '206/246' started by F40-R, Feb 7, 2017.
  1. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    #1 F40-R, Feb 7, 2017
    What an exciting day, I've finally picked up my 246 GT flares with no chairs car. I drove it from the countryside all the way to the CBD, which took just over an hour and now the car won't start 🙁. Nonetheless, I'm happy and excited at the same time so here are the pics!
    Time for some much needed TLC and seeing that this car is completely original, which means, it has never been resprayed, never pulled apart and having travelled only 37,100kms with all of the original books, invoices and a full history log file. I've decided to continue on with its legacy of keeping it an original car that may enter a preservation class at concours.
  2. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    #2 F40-R, Feb 7, 2017
  3. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    #3 F40-R, Feb 7, 2017
  4. TTR
    TTR F1 Veteran
    5,890
    Riverside, CA
    Timo
    Oro Chiaro ?
  5. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    fantastic...
  6. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    Yes, correct.
  7. Rory J
    Rory J Formula 3
    May 30, 2006
    1,133
    Dinos are sometimes a bit tough to start from hot. If you hold the throttle to the floor while cranking, that clears the carbs and can help.
  8. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    Only problem is that it won't turn at all, doesn't click over... I'll give it a go this morning, if it does the same thing then I think that the starter motor killed itself. Tried a jump pack, that didn't help, so the battery is full of life I would think. Trying to rule out a few problems...
  9. 500tr
    500tr Formula 3
    Feb 28, 2004
    1,218
    Germany
    Volkmar Spielmann
    Starter motor, common problem...
  10. possum
    possum Formula Junior
    Sep 27, 2008
    307
    australia
    johnno
    Congratulations,I had a similar problem and the late John Corbani advised me to get the biggest battery that would fit which was 800 cranking amps worked a treat,I tried the obvious the usual battery packs etc didn't work for me good luck, you have a gem these sort of issues are frustrating but your knowledge about these cars will improve out of sight and this Forum is the best place when you have issues.
  11. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,659
    NOLA
    Chris
    Incredible! Congrats.
  12. ODDY
    ODDY Rookie
    May 7, 2013
    17
    Congratulations, non original horn button.
  13. HMB-Dino
    HMB-Dino Formula 3
    2,282
    Pebble Beach, CA
    RonG
    ^^^ ring surrounding center should be chrome, repros always seem to be black plastic
    Steering wheel also on the wrong side...;)
  14. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    Figured out that it's the battery, so I have the biggest battery on it's way!
  15. TTR
    TTR F1 Veteran
    5,890
    Riverside, CA
    Timo
    #15 TTR, Feb 7, 2017
    Before replacing the battery, I'd test the old one first and if found to be OK, leave it in and look for insufficient ground or loose contact somewhere in the starter circuit !?!
  16. DinoLasse
    DinoLasse Formula Junior
    606
    Sweden
    Lars
    Allow me to disagree on the bigger battery. It will not buy you anything. Find the real cause of the problem instead.
    TTR's suggestion is much better. Connections are the first thing to check, grounds in particular. Oxidation and poor contacts are common in older unrestored cars.
    But my vote for Most Likely Culprit is the ignition switch. Notoriously troublesome. If you don't hear the loud click of the starter solenoid engaging, then that is the problem. Just put a jumper clip across the ignition switch under the dash and you will be cranking again.
    If the solenoid is engaging but the starter is unable to crank the engine, then the starter is defective and has to be rebuilt. Also very common, as 500tr mentioned.
    But congratulations on the car. You seem to have found an unmolested original car in excellent condition. It looks fantastic.
  17. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    #17 F40-R, Feb 8, 2017
    Cheers to all...! The seller was great, he organised a tow truck to pickup the car and drop it off at a reputable Dino restorer and they went through the car and discovered that the battery was tired, so they replaced it with a new one. Car cranked and on it went onto the truck 😀
  18. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    #18 F40-R, Feb 8, 2017
  19. 500tr
    500tr Formula 3
    Feb 28, 2004
    1,218
    Germany
    Volkmar Spielmann
    pm sent
  20. GIOTTO
    GIOTTO F1 Rookie
    Dec 30, 2006
    3,916
    France
    Congratulations. The color is just beautifull. Is it possible to have the VIN please ?
  21. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,517
    Metro Detroit/Encino
    Steven
    Oro Chiaro.....awesome!
    Congrats.
  22. Topes
    Topes Karting
    Sep 6, 2015
    50
    Charleston
    Ryan
    looks great. How tall are you? I'm 6'3 and it's a tight fit. Are you comfortable?
  23. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
  24. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,659
    NOLA
    Chris
    Great video. Thanks for sharing!
  25. lucca
    lucca Rookie
    Oct 8, 2011
    7
    Princeton, NJ
    Steven Cohen
    Very nice car, beautiful color. Looks to be in very nice shape.
    Enjoy. I would like to know the S/N
