458 - Pics of your 458/488 in regular parking spots | Page 16 | FerrariChat
458 Pics of your 458/488 in regular parking spots
Discussion in '458 Italia/488/F8' started by billboboy, Apr 17, 2019.
  1. ridege55
    ridege55 Formula 3
    1,385
    Manhattan Beach, CA
  2. ridege55
    ridege55 Formula 3
    1,385
    Manhattan Beach, CA
  3. Mikael-F360
    Mikael-F360 Formula Junior
    Apr 3, 2017
    754
    Finland
    Mikael E.
    mdrums and soulsea like this.
  4. Mikael-F360
    Apr 3, 2017
    754
    Finland
    Mikael E.
  5. fastmnstealth
    fastmnstealth Rookie
    Jun 23, 2017
    42
    MN
    Mark
    Picking up some 4x8 sheets of plywood.
      File size:
      69.2 KB
      479
  6. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    4x8 inches? Don't have enough place in the luggage compartment... or did you tie them up on the roof of the car???
  7. jdlegg
    jdlegg Formula Junior
    Dec 22, 2009
    252
    Bryan / San Rafael
    James D
  8. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    NICE!
    jdlegg likes this.
  9. 997_T_u_r_b_o
    997_T_u_r_b_o Rookie
    Nov 14, 2020
    35
    Steve S.
  10. RoadRonin
    RoadRonin Formula Junior
    514
    San Francisco
    Fronts – 20x9 et40; 245/35-20
    Rears – 21x12 et50; 355/25-21
    You may want to go with a less aggressive offset in front to prevent the possibility of rubbing should you decide to go this route. I did this purely for the way it looks as this is not a performance mod.
  11. fastmnstealth
    Jun 23, 2017
    42
    MN
    Mark
    I had to get help from the Home Depot staff, but I got them on there :)
    Viperjoe, dbalcar, jc1 and 4 others like this.
  12. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    Man, do they build hose Ferraris TOUGH! Almost sounds like Ferrari stole something from Ford; or was it the other way around? And talk about that suspension! I assume you put it in RACE mode!
    Very credible. You certainly have a gift. Talk to Hollywood or Lucas Arts. CGI is your thing!
    Thanks for making me laugh.
    LOL
    fastmnstealth and Mikael-F360 like this.
  13. Dicecal
    Dicecal Formula 3
    1,859
    Phoenix, AZ
    Rob
    Was the change noticeable with the oversized rears? Rides harsher, better traction?
  14. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    940
    San Diego
    Rob Barry
    These cars are great. A friend asked me to help move a refrigerator with mine:
    Ok, it was a mini-fridge.
  15. RoadRonin
    514
    San Francisco
    Ah ... typo. My wheels are actually 21/22:
    Fronts – 21x9 et40; 255/35-21
    Rears – 22x12 et50; 335/25-22
    Apologies for any confusion. I've said in previous threads that if I had to do it all over again I probably would have gone 20/21 in order to reduce the impact I'm about to describe in the following paragraph.
    Due to the shorter sidewall, the ride will be slightly more firm. Additionally, the larger tires are heavier. This setup does add understeer to the cars driving dynamics. One benefit is that the car does feel more stable/planted and less twitchy. If you enjoy the rear-end getting loose then this configuration may make you lose a little bit of that. If you plan to track the car this is not the setup as it is not optimized for performance. This car has been optimized for looks. I personally don't mind the slight degradation in performance. I'm still able to enjoy very spirited drives without issue.
    Even the Ferrari P/80C one-off (built by Ferrari’s Special Projects division) runs 21/22 as its concourse/car show mode. For the track, it runs 18s.
    GT2goneF likes this.
  16. GSF355
    GSF355 Karting
    55
    Brisbane
  17. ridege55
    ridege55 Formula 3
    1,385
    Manhattan Beach, CA
    Vorsteiners
    GSF355 likes this.
  18. soulsea
    soulsea Formula 3
    1,387
    29464
    Loxo, Boots, mdrums and 3 others like this.
  19. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    Nice vehicles for the occasions.
    soulsea likes this.
  20. James R
    James R Karting
    Jun 6, 2020
    102
    Missouri
    James Richards
  21. rob5819
    Dec 12, 2017
    940
    San Diego
    Rob Barry
    Can you give any specs on your lift? How high is your ceiling, etc.? It would be a great solution for me, but I worry my ceiling is just not high enough and has sprinklers, lights, etc.
    Thanks,
    Rob
  22. James R
    James R Karting
    Jun 6, 2020
    102
    Missouri
    James Richards
    Sure. The ceiling height is 10’ 1”. I had the garage door company come out and refit the door with a “high-lift” kit. Basically they change out the standard ceiling mount opener with a side mount and replace the tracks to allow the door to go higher. I did have to remove the two light bulbs that the door would have hit but the new opener comes with a flat mounted light. The lift itself is the Challenger CL7 which is designed for shorter ceilings. It is NOT bolted to the floor but comes with special castors that work as fulcrums when the lift is down (and no cars on it) to move the lift around the garage with ease. Lift cost about $5,675 installed and the garage refit was about $1,450.
    Wildwoody, BJK, iMrMark and 5 others like this.
