Picture request, F355C rear wing bracket | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by kenneyd, Feb 23, 2017.
  1. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,015
    NE FL
    Ken
    I am looking for a picture of the under side of a dealer installed 355 challenge wing bracket.
    I'm just want confirmation of the rivets size, and where the bolts access holes where cut.
    Thanks guys
    Sent from my LGLS990 using Tapatalk
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
  3. KMR968Turbo
    KMR968Turbo Formula 3
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
    That looks way too clean. Do they call you Edward Shammie Hands? ;)
  4. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,015
    NE FL
    Ken
    Exactlty! Ands I assume they all were done the same way?
  5. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,015
    NE FL
    Ken
    And one more question while we are on the subject, do all challenge lids have the hood pins on the side?
  6. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    Yes. When the F355 Challenge got the rear wing, dzus fasteners were required: Table 5 - REAR WING
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Yes if you did not tie the led down it would buckle where the fastener is. I have seen it on other models and done it myself at speed
    Correct each side was the same
  8. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    #8 308 GTB, Feb 24, 2017
    Ricambi America has the right hardware for your application. Drilling of your rear deck lid and rear clip is required to rivet mount the dzus fasteners and brackets with springs. Most of the Challenge cars I've seen have the ring type fasteners as Daniel has pictured in his parts diagram.
  9. KMR968Turbo
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
    I was wondering why the dzus fasteners were needed when you still had a latch at the back/center of the deck lid. Are you saying the wing pushed down on the lid causing the center to rise up/buckle?
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    #10 SoCal1, Feb 24, 2017
    Yuup, they buckle up in front of the wing
    Pull back on the wing you will see it move
    The reinforcement rods help disperse the load also more forward
