Pictures show up on camera, but not computer...help?
Discussion in 'Technology' started by BlackBird007, Apr 14, 2012.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. BlackBird007
    BlackBird007 F1 Rookie
    Feb 22, 2010
    3,180
    DFW
    Kevin
    I have a Canon EOS Rebel XS, containing a SanDisk SDHC 4GB card. I took alot of pictures today. For some reason, they show up on the camera, but not in Windows Explorer, when I try to import them. Is there a fix to this? I sure hope so...
    Some older pictures from other dates show up, but not the ones I took today.
  2. TheDuke
    TheDuke Formula 3
    1,768
    Texas
    Dude that sucks!! Sorry to hear that. Hopefully you get it fixed because I bet you got some good pictures today.
    Good luck
  3. Jedi
    Jedi Two Time F1 World Champ
    Mar 18, 2008
    27,542
    Seattle Area
    Jedi
    Are you running WinXP? Sounds like your computer cannot read an HDSD card - older
    computers can only read up to 2gb SD cards. I think there's a hot-fix for WinXP for
    HDSD, but only if your actual reader is HDSD compatible as hardware.
    Jedi
  4. BlackBird007
    Feb 22, 2010
    3,180
    DFW
    Kevin
    I'm running Vista 32-bit. I have the card in the camera, and the camera is connected to the computer via USB. I've never had this happen before.
  5. BlackBird007
    Feb 22, 2010
    3,180
    DFW
    Kevin
    I've managed to copy a handful over using a Canon program on my computer, but it's more time consuming than WE, as you have to select each and every one of them (took 164 today) to copy, whereas you could just click, drag, and highlight in WE.
  6. Zack
    Zack Formula 3
    Dec 18, 2003
    1,673
    Nicosia, Cyprus/Cali
    Zacharias
    Just use a friend's computer. And upgrade yours.
  7. Tired of seeing this ad? Upgrade now
  8. Jedi
    Mar 18, 2008
    27,542
    Seattle Area
    Jedi
    Still sounds like an SD vs. SDHC issue. Older Windows SD readers can only address up
    to a 2GB SD card. Anything larger just cannot be read. There's a hotfix for both Vista
    and XP to handle SDHC cards, but if the reader isn't compatible it still won't work. Your
    camera is SDHC capable, so it can read the card just fine.
    Jedi
