http://www.speedydelivery.co.uk/car-tuning-power/ Has anyone used this product? Sounds too good to be true, especially for the price.
It's just a $0.01 resistor that causes an air-intake-temperature sensor to report colder air temps to your computers...which essentially makes your car run richer than it would otherwise run in normal driving (no impact on Wide Open Throttle or Idle).
What you need is a fuel controller. I gotta figure this out. You can use them when you run nitrous to increase fuel to the efi injectors. Then you don't have to deal with the provlem of flowing a wet mixcture in a dry manifold. The trick would be to figure out how to piggyback it on the OEM EFI and increase intake airflow dump more gas and basically have normally aspirated hotrodding.
