Pigtail for Battery (Ctek) charger to Fit OEM charger plug... | FerrariChat
Discussion in '360/430' started by mtmilam, Oct 29, 2014.
  1. mtmilam
    mtmilam Formula Junior
    Oct 24, 2009
    440
    Lafayette, LA
    Mark Milam
    #1 mtmilam, Oct 29, 2014
    I just received my Pigtail from a F chatter....wkumari.....from Virginia. Its for my 2008 F 430 spider, gated 6 speed.
    This pigtail plugs into the OEM pigtail that was installed by Ferrari, at factory...I didn't have the Ferrari Charger, but a Ctek 4.3.......Ctek does not make this plug but Warren found a supplier and will make up a pigtail for you. That way, when you plug your Charger in, It shows it on the instrument Cluster as a warning light.....If you try to drive off with charger still plugged in. And its convient just to reach under dash and plug it in, with one hand. :D
    If you want one, give Wkumari a PM or something. Its a "one handed" Hook up which I like.
  2. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    That's convenient. I have the same pigtail and tender.
    Alan
  3. mtmilam
    Oct 24, 2009
    440
    Lafayette, LA
    Mark Milam
    #3 mtmilam, Oct 30, 2014
    Here is a picture on your display if you try to start the car with charger plugged in....And if you hit start button, it Won't turn over or start.....
