Pilot Dies From Hand-Propping Propeller Accident | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by toggie, Jan 31, 2012.
  1. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    i saw pics of guys turning over b-17-b-29 4 eng planes by hand ,but i dought trying to start
  2. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    Those guys were turning the prop blades to push out oil that had collected in the lower cylinders while the engine was sitting for a lengthy period of time. The clearances between the pistons and cylinder walls are great enough to allow oil to drain from the case down into the cylinder heads of the bottom cylinders. If this incompressible oil remained in the cylinders when the combustion took place it would blow the cylinders off or bend the master rod. Most usually it was the latter, however I have seen both. So, it is wise to push the 60 weight oil out before starting the engine. The remaining oil is the cause of the dense blue smoke when the engine starts, then as the aluminum pistons get hot and expand to close the clearances between them and the cylinder barrel, the smoke stops. It is now standard procedure to crank the props around several blades instead of pushing them because the starters will not apply as much pressure on the cylinders. Sounds like I just made all that up.
  3. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    I should have said pressure on the connecting rods, not cylinders.
  4. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    ...and if one looks closely...whenever the props are pushed through it always is backwards...another safety measure at work
  5. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    You can tell it's been more than 20 years since I propped an airplane... I had completely forgotten that rule, but I strictly adheared to it back then... Some things stick in your mind and others don't...
  6. Ike
    Ike F1 Rookie
    Nov 4, 2003
    3,543
    Is there some sort of external starter that could be used?
    Maybe a large version of a r/c plane electric starter. It could be on wheels and pushed up to the plane and spin the prop.
  7. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,572
    FL
    Probably has been designed, but seems like a lot of extra cost when it can be done by hand for no cost (just the risk for those not as experienced ;)). Or if you have an SR-71 Blackbird, you can lend your 454 engines to start a friend's. :)
  8. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,403
    Seattle Area
    Dave
    I always like your wry little comments at the end of some of your posts... you crack me up!
    Jedi
  9. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    They had this device in the 20's and 30's that was mounted on a Model T or equivalent. Set at an angle to match the crankshaft of the engine and prop shaft, the truck drove up to the airplane until the starter cog on the end of the shaft engaged the mating cog on the prop shaft and cranked it over. It was called the Hucks Starter. You Tube has video footage of this being used on the 1934 Hawker Hind and Hawker Demond or Nimrod. Worked great.
  10. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Of course there had to be one everywhere you landed, or you were back to hand propping it.
  11. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    Those Hawkers were also equipped with " stem winders", cranks inserted into the right side of the bonnet that permitted the mechanic to wind up the inertia starter or, in a few cases, crank the engine until the impulse mag kicked in.
  12. Tcar
    Tcar F1 Rookie
    Hucks Starter, with a pic:
    https://en.wikipedia.org/wiki/Hucks_starter
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
  14. Ike
    Ike F1 Rookie
    Nov 4, 2003
    3,543
    That is really interesting, I'm going to look for those videos.
  15. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    thanks,
