Pista- Dead Lithium Battery Solution | Page 3 | FerrariChat
Discussion in '458 Italia/488/F8' started by gthompson, May 10, 2024.
  1. Gooey
    Gooey Karting
    Jul 28, 2018
    65
    Gooey
    How was the install?
    How is it working?
    Can you share the contact for Andy?
  2. frogwo
    frogwo Formula Junior
    Jan 15, 2005
    283
    Please provide the contact information for Andy. Thank you.
  3. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    I installed the battery last weekend and the battery started the car and everything was working great and the external charger was charging the battery. I had a stop/start error light that came on. I drove the car for 45 minutes and I had shut the car off and turned it back on a few times. No issues
    That battery works great, except that stop/start light stays on. I have never used the stop/start on the car before, but it only has 1,300 miles on it since I bought it new in 2020
    I took the car to Ferrari and they said that the battery had a temp sensor that was bad. So yesterday, I sent the battery back to Andy, He said that he could either repair the temp sensor or replace it.
    Andy's email is:
    [email protected]
    Thecadster likes this.
  4. Thecadster
    Thecadster F1 Veteran
    7,576
    It’s been said before, but it’s worth saying again. The Pista battery situation sucks. If we can put a man on the moon, Ferrari should have been able to supply the Pista with a proper battery setup.
    vraa, mdrums and Art138 like this.
  5. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    Lol, I agree!, but I have a friend that believes that we never landed on the moon and that it was staged in Hollywood :)
    vraa, Thecadster and ACSATCO like this.
  6. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    I meant to add that Ferrari has an old lithium Pista Battery that they use to test or move a car with a dead battery.
    They unplugged my new battery and plugged the old battery in, and the car started and did not show the stop/start error, so they were sure that it was a bad temp sensor in my battery
    vraa likes this.
  7. sfcarguy
    sfcarguy Formula Junior
    524
    Earth
    Are you sure that the dealer specifically traced the problem to a temperature sensor in the battery itself? No where in A123's documentation do they mention temperature when boasting about how intelligent their BMS is. Not trying to call you out here, just genuinely curious as I would've thought that A123 would list that as a capability.
    See pg. 3-4 in the attached PDF
    vraa likes this.
  8. sfcarguy
    524
    Earth
    #58 sfcarguy, May 23, 2024
    Here's another really detailed document from A123 on the design of battery packs and BMS for EVs.
    "Ideally, the temperature of every series element or cell would be monitored by the BMS; however, it is not as important as voltage, and is often impractical in cost-effective systems. A high-temperature condition is typically the result of monitored voltage and current conditions either being out of bounds or caused by an external thermal source." pg. 46
    vraa likes this.
  9. Pat488
    Pat488 Karting
    Sep 4, 2023
    125
    Melbourne, Australia
    Pat
    Every lithium battery should have temperature monitoring. It doesn’t need to be stated, it’s a given.
  10. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    The dealer told me that there were 2 temperature sensors and then Andy confirmed that, so I guess that there are temperature sensors?
    sfcarguy likes this.
  11. sfcarguy
    524
    Earth
    #61 sfcarguy, May 24, 2024
    Should being the operative word because a lithium 12v battery should also last more than 4yrs in a car that’s not driven regularly if kept on a tender.
    Pat488 likes this.
  12. Pat488
    Pat488 Karting
    Sep 4, 2023
    125
    Pat
    Should last a minimum of 10 years or even 20 with limited use that these see, providing optimal storage conditions. The problem is keeping them fully charged for prolonged periods. For the longest service life, lithium likes to be kept at 40%-60% SOC at around 20 Celsius. The higher the charge and the higher the ambient temperature, the sooner the battery will die. So, keeping the battery fully charged on a tender is one of the main things that are killing the battery.
  13. sfcarguy
    524
    Earth
    The 296 and SF90 both have a long term storage mode in the menus that will automatically enable after 10 days (I think) to keep the hybrid battery at ~50%, but there's no lithium 12v tender on the market that I'm aware of that allows you to hold the battery at anything less than ~90%.
    Pat488 likes this.
  14. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    I have great news!
    We were having an issue with the stop/start light coming on after replacing the lithium battery with the refurbished lithium battery
    Andy, Mr Lithium who refurbished my battery said to do a hard reset on the car
    There are 2 separate ways to do a hard reset to eliminate the errors
    With the battery fully charged:
    1st option
    Lock and unlock the car with the key 3 times.
    2nd option
    power ON and power OFF the car 3 times.
    that should reset everything.
    The Ferrari dealer did that on my car and it worked
    They had to do both options 3 times for this to work
    The error light is off and the car is operating normally
    I just got a call from the dealership and they said that the car is ready to be picked up
  15. Drewcati
    Drewcati Karting
    Jul 9, 2014
    60
    Texas
    Great news, thanks so much for the update @gthompson. Am I correct in saying that the only question that remains is regarding @MANDALAY's question about the combustibility of lithium and the implications for our warranties?
    Also, I skimmed through the thread again to look for pricing and turn time. Can you please share that either publicly or privately?
    Thank you again @gthompson for your work. As a likely keeper of my Pista, this is very valuable to me. My car goes in for its annual this week. I'll let everyone know what my dealer has to say.
  16. Pat488
    Pat488 Karting
    Sep 4, 2023
    125
    Pat
    Both questions answered, see post #14 above.
  17. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    Thank you Pat488 for listing that post number
    I knew that the fire hazard was discussed and I mentioned the price of $1995 that I paid. I just didn't know where on this thread that discussion took place
    Here is post 14 from Pat488:
    The cells used are Lithium Iron Phosphate, or LiFePO4 and that chemistry is safe and stable. It is not the same chemistry as is used in most EV’s, E-Bikes, phones etc. They use Nickel Manganese Cobolt, or NMC chemistry and it are those cells that like to catch fire.
    At a refurbishment cost of $2k, it is well worth it.
    Drewcati and Pat488 like this.
  18. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    Andy turned my Battery around in 2 weeks which included ground shipping both ways, so it wasn't bad at all. He mentioned that he had ordered a bunch of Lithium cells now that he knows the refurbished batteries work and do not throw off any error codes
  19. Pat488
    Pat488 Karting
    Sep 4, 2023
    125
    Pat
    If none of the battery electronics are changed, there is no way the vehicle can detect that the cells inside the battery have been changed. There should be no error codes at all.
  20. Drewcati
    Drewcati Karting
    Jul 9, 2014
    60
    Texas
    Thank you Pat! I will ask my dealer about warranty implications using aftermarket refurbishment.
  21. Pat488
    Pat488 Karting
    Sep 4, 2023
    125
    Pat
    I can already assume the answer to that...........
  22. gthompson
    gthompson Rookie
    Apr 15, 2008
    27
    Dallas, Texas
    George Thompson
    I agree, but for some reason I was getting the stop start error light. That may have started because of the torn temperature sensor
  23. Drewcati
    Drewcati Karting
    Jul 9, 2014
    60
    Texas
    Same here
    Pat488 likes this.
  24. Pat488
    Pat488 Karting
    Sep 4, 2023
    125
    Pat
    Doubt that came from the repacked battery. As you said, most likely the temp sensor or just the fact that the car sat without a battery for a couple of weeks and then required a reboot when the battery was reconnected. It could have happened even with a new factory battery.
    Anyhow, all good now. ;)
  25. Drewcati
    Drewcati Karting
    Jul 9, 2014
    60
    Texas
    Picked my car up today from its annual. Clean bill of health
    Word from the service advisor on the topic of this thread:
    1. They have had a client who refurbished his Pista lithium battery through what sounded like the same vendor in this thread.
    2. The car initially had trouble recognizing/functioning with the battery but after a little work, the dealer was able to successfully perform the relearning process. I believe it is likely the same process described in this thread.
    3. The dealer offers the same lithium to non-lithium AGM conversion for about 5k.
    4. If there were to be an issue with a component that was covered by the full manufacturer's or Power15 extended warranty, Ferrari would have to prove that it was caused by the refurbished lithium battery.
    All the above to say, predictably, refurbish at your own risk. If you want to play it safe, have your dealer complete the non-lithium conversion and then simply replace your lower cost AGM battery as needed.
    So far, I seem to be one of the more fortunate ones with no issues and I'm very grateful. With my 458, even on a new AGM battery and plugged into the tender when not in use, it felt like a flip of the coin whether it would struggle to turn on. I feel like with the conversion, I'm going to return to the unreliable days of my 458. I'd love to keep a lithium battery in my car. I hope I'm one of the people whose lithium battery stays healthy for 10+ years.
